Exterior light bulb warning
01-02-2014, 11:25 AM | #1 |
Rep 3
Hi All,
New member and to Beemers, got a 07 320M sport coupe and 2 weeks in the warning light comes up, but there are no light bulbs dead. Took it in to Halfords and all bulbs work. Is this common? Next stop Synter BMW Any ideas? Cheers, Dylan |
01-02-2014, 11:38 AM | #2 |
Rep 1,681
Very common, make sure to clean the connections. Sometimes if it's corroded/dirty it will trigger the light. It's all based on resistance so anything out of what it expects will trigger the warning even if all bulbs work.
01-02-2014, 11:47 AM | #3 |
Rep 4,265
Someone may have fitted aftermarket LED's.
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
01-02-2014, 12:31 PM | #4 |
Rep 614
Also check the rear brake light bulbs. There Are two in each lamp that illuminate when the brakes are pressed. So you may have one of the bulbs out, but the other bulb will still illuminate the brake light, making it look like no bulbs are out!
01-02-2014, 01:15 PM | #5 |
Rep 3
Thanks guys for the replies, I've checked the connections,took covers out from boot and had a look, all bulbs are clear and work.
Might be LED's gone wrong or one of the many exterior bulbs. Will take it in to BMW anyways. Cheers |
01-02-2014, 02:48 PM | #6 | |
Rep 1,060
CD ID then a number, If you search on this forum for the codes it will identify the problem bulb. One of the areas on an E92 is the Brake Force Display which will only illuminate on activation of the ABS. Hope this helps. |
