Side mirror issue.
01-04-2014, 08:16 AM | #1 |
Rep 71
Ok, so I've had my car for just little over a week and then noticed this little issue with the side mirror. After parking up and possibly locking the car, the mirrors tilt to a real weird position. Initially, I thought the mirrors had the function to fold inwards and possibly having problems with the motor but I don't think that's the case.
Any ideas what the problem could be? Might I add that it seems its just the drivers side mirror. Could be wrong.
BMW E92 325I M SPORT
01-04-2014, 08:39 AM | #2 |
Rep 9,097
If you have memory seats, then worth of exploring that.
01-04-2014, 08:51 AM | #3 | |
Rep 71
01-04-2014, 09:28 AM | #4 |
294
Rep 2,602
Key memory/settings? Try locking with the other key?
BMW mirrors do not auto fold in (like MB); there's a little button near the mirror adjust. Maybe also try "re-saving" the memory position and mirror settings. |
01-04-2014, 09:30 AM | #5 | |
Rep 71
01-04-2014, 04:51 PM | #6 |
Rep 572
I have the same problem and found this DIY post, but haven't tried it yet...
http://www.e90post.com/forums/showthread.php?t=683764 |
01-04-2014, 05:26 PM | #7 |
Rep 141
I had this issue. Followed the above fix.
The contacts on the connector on the mirror motor build up corrosion. A quick rub of the contacts and the application of dielectric grease to keep moisture out sorted my issue. Very easy to do. Remove mirror glass and then remove one screw that holds the motor in place, pull the motor straight out and clean contacts on the motor unit itself. Problem solved.. |
01-05-2014, 04:10 AM | #8 |
Rep 480
Same here had the drivers mirror go into a random position every time I locked the car, cleaned the connections to the motor and all good now
Very easy to do 10/15 min |
03-02-2014, 01:15 PM | #10 |
Rep 3
Just in case you don't want to try dismantling the motor and would prefer to replace it (from ebay, lets say) you can use your mirror and back case and buy only the skeleton mirror, around 100 bucks on ebay. Here's a video that shows how to stop the mirror from folding outwards every time you lock/unlock your car, until you've bought a replacement.
