Driving me mad
01-08-2014, 02:50 PM | #1 |
Rep 63
Driving me mad
Hi guys I have an E46 330i M Sport on MV1's and the front drivers side tyre keeps going flat....it's driving me insane as I've done the following:
Had the tyre checked by 3 garages, all confirmed the does not have a puncture, they suspect it's the wheel and it needs cleaning and refurbing. Had the wheels refurbed, they confirmed at the time the wheel also has no cracks, after it was done tyre still going down went back to the place and leak test done and it's coming from the tyre wheel area, re sealed and tested by refurbished all fine for a month Then 2 days ago down to 15psi again , back to a tyre place incase it's an actual puncture, no, leaking from the same place! Whats going on? Any further help appreciated Last edited by stugolf; 01-08-2014 at 03:02 PM.. |
01-08-2014, 03:18 PM | #2 |
Rep 2,048
Are you using the same tyre? sometimes tyres tend to have hairline cracks which cant be seen or not warrant enough to see air leaking in a bath but over time lose air
wheel may be buckled slighltly causing the tyre not to bead fully? not annoyed someone lately? maybe someone letting you air down over period of time? |
01-09-2014, 04:21 AM | #4 |
Rep 63
Thanks for the responses guys
I haven't seen the wheel without the tyre off first hand but the refurber seen nothing wrong with the wheel when he had the tyre off and confirmed it could seen anything wrong with the actual tyre I know where its leaking from so must be a problem with tyre/wheel combination but it really is baffling as to which it is! I could buy a wheel but would then have to get it refurbed and then possibly buy a tyre so could get quite expensive too seeing as I've only just refurbished these wheels! |
01-09-2014, 04:34 AM | #5 |
Rep 891
heres a thought:
mark the tyre and the wheel where the air is leaking. remove the tyre and rotate it so the mark on the tyre is on the opposite side of the wheel (180deg round from the wheel's mark) then refit. see if the leak moves with the tyre, in which case the tyre is goosed. if it stays where the wheel is marked, then its the wheel that's damaged. |
01-09-2014, 04:50 AM | #6 |
Rep 1,184
soak the whole wheel in soapy water with a sprayer, bubbles will form from escaping air... my bet is the tyre isn't beading properly...
PAST: 2007 E93 335i 6MT NOW: 2012 F10 M5 Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr THE BUILD THREAD|COMPILATION OF PHOTOS |
01-09-2014, 08:19 AM | #8 |
Rep 1,271
Drives: 335i (sadly gone)
I know you said you know where the tyre is leaking from but have you checked the valve is not leaking? It's the only thing that hasn't been mentioned and maybe it is that this time?
01-09-2014, 08:25 AM | #9 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
As above, always check the valve. Common for air to leak if it's not tight....
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
01-09-2014, 08:57 AM | #10 |
Rep 63
Thanks Guys
Will check this, next things to try: Take the tyre off and properly inspect the wheel and tyre myself Make sure the valve is nice and tight Refit and put the pressure up and then back to normal I'll let you know how I get on |
01-09-2014, 09:41 AM | #11 |
underground
64
Rep 332
Drives: alpine white 335 E92
Up the air pressure & Put it in the tub and watch it like a hawk.
