OpenFlash Tablet Set-Up and Install
01-16-2014, 03:51 PM | #1 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Hi guys,
We made a few updates to the Template (new graphics) and Protocol to simplify things a bit. Instead of having MSD80/81 N54, MSD80 N52 and MSV70/80 N52 support on the same Template, we divided them up in 3 different Templates that you can upload yourself through the OpenFlash Manager software. This will prevent customers from accidentally configuring the device for the wrong car and not have access to some of the model specific features provided by the OFT. The following instruction is for those with MSD80 DME (2007 and up) Several updates in the last few days so I'll go through things step by step. The following process should be done by all. Even those who configured the OFT correctly for their car. Mind you, even if you configured the OFT incorrectly, it will still read/write to the DME perfectly fine. But you will miss out on a few features so it's best to do it correctly at this early stage (pre-tuning). Of course, new units are now being shipped out with all these updates so new users who receive their units next week can skip over Steps 2, 3 and 4 Step 1: Download the OpenFlash Manager v1.06. This is the application used to load tunes, update template, download datalog files, etc,. It's a new version that was just made available last night. Just download it and run the setup file. It will automatically overwrite any older version so there is no need to delete any old files manually. Very simple. You can download OFM 1.06 here: http://www.procedetuning.com/328i/do...s-4/index.html Step 2: Connect OpenFlash Tablet with a WIFI connection on your laptop. Let it run through the firmware update process. It will update to firmware 121 which was just made available last night. After the update process is complete (it may take over a minute), confirm that you see FW ver. 121 displayed on the OFT screen. Step 3: To go Erase Data section and erase data. This will completely erase the device. There is no need to back anything up since you will re-read your stock DME again (it takes an hour). This is assuming you haven't modified your ROM at all. Which I assume is the case since we haven't posted any tunes up yet If you haven't installed the OFT yet (didn't do the initial DME read), you will get a message saying "The device has never been used". If so, move on to the next step. Step 4: Download the MSD80 N51/52/53 Upgrade Template file (.SLT) from here: http://www.procedetuning.com/328i/do...s-4/index.html Go to "Upgrade" Section and select this file. Press "Start". This process will take 30 seconds or so. When done, disconnect OFT from laptop and go to your car. Step 5: Plug OFT into vehicle. Go to Tuning section. Select your vehicle. When you highlight your vehicle, confirm that you see "Siemens MSD80" written at the bottom of the screen. Then continue and read the DME. This process will take 1 hour so make sure you have a reasonably healthy battery and that your headlights, stereo, interior lights, etc,. are turned off. Ignition power must be fully ON. This means that you will see the fuel gauge give a valid reading. Also, opening closing doors can turn off ignition unexpectedly as well, possibly aborting the reading process. So we recommend rolling down the driver's side window, closing the door and doing this process from outside the car. Presumably your arms will be long enough to press the ignition button and plug the OFT into the OBD2 port When the reading process is done, you will get a message notifying you and asking you to turn off ignition and press OK. So press OK. Step 6: Now we will test the realtime data display. Start the engine. Navigate back to main menu in OFT. Go to Diagnostics and select Realtime Display. You should see this: Confirm that you see Airmass and Relative load channels in there (3rd and 4th in the list). The presence of these two channels confirms that you have the correct non-turbo protocol loaded. If you have the N54 protocol loaded you will see Boost Target and Boost Actual there instead. Step 7: Disconnect OFT from car and connect it to your laptop running OpenFlash Manager. Go to Download Data and download the "original file". Then please email this file to me (@ shiv@vishnutuning.com) if you haven't done so already AND confirm that you have the correct protocol loaded. I will respond with a tune file for you to upload Cheers, Shiv P.S. Apologies for asking you guys to install the device a second time. I know that 1hr long read is a pain in the butt. But it's best we do this correctly now from the start. |
01-16-2014, 05:07 PM | #2 |
Rep 2,114
In the read process now. Should be good to go in about half an hour.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
01-16-2014, 05:29 PM | #4 |
1748
Rep 17,960
Drives: A Lot
01-16-2014, 05:41 PM | #6 |
1748
Rep 17,960
Drives: A Lot
01-16-2014, 05:53 PM | #7 |
Rep 2,114
Read complete. Shiv, if we already did a read on the DME prior to this update, do you want us to send the new read as well or does it make any difference?
01-16-2014, 05:56 PM | #9 |
1748
Rep 17,960
Drives: A Lot
If you already did a read before and emailed it to me, the new read file you generate now will be the same. But might as well email it to me anyway. Along with confirmation that you are on the correct protocol.
01-16-2014, 05:57 PM | #10 |
Rep 2,114
Cool. Sending now.
01-16-2014, 06:05 PM | #11 |
No 55mph
1622
Rep 8,477
Excellent instructions - worked flawlessly thru to the end
Now have new/correct protocol Sent you my new Original ROM 1-16-14
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
01-16-2014, 06:30 PM | #13 |
1748
Rep 17,960
Drives: A Lot
Emails answered! Please email me directly if you have any issues. It just so happens that there are a lot of new things happening all at once so I reserve the right to make mistakes this first round
Shiv |
01-16-2014, 06:46 PM | #14 |
Rep 2,114
I guess I volunteer as the first one to get an error on this process.
01-17-2014, 04:12 AM | #16 |
1748
Rep 17,960
Drives: A Lot
Hi just took a closer look at the ROMs that you guys sent me. Several of your guys have ROM type (CAL ID) MI20S. Funny thing is is that when I actually compared all M120S ROM files, they don't all share the same mapping values which is unlike any other MSD80/1 ROM I've seen. Usually, if two ROMs share the same CAL ID, they share these same mapping values. So it looks like I will have to create tune file individually for many of you guys since the patch function won't work if the original ROM files are different (useful safety feature). Which is probably why a few of you guys didn't see an automatically generated tune file when you uploaded the .dev file I emailed you.
I'll be doing this tomorrow (it's 2.10am now) and my eyes are blurry for looking at hex so map editing isn't the best idea right now shiv |
01-17-2014, 05:15 AM | #17 | |
No 55mph
1622
Rep 8,477
01-17-2014, 08:48 AM | #18 |
Rep 163
So, sitting in the car right now. Hopefully doing everything correctly. Initially bought an 325i, but with the 3 stage manifold and the tune it should at least be a 330i. Therefore i selected 330i. So, lets see what happens.
Edit: everything went well. Send you my file, shiv. Last edited by KingofKingz; 01-17-2014 at 10:26 AM.. |
01-17-2014, 02:42 PM | #20 |
1748
Rep 17,960
Drives: A Lot
All issues should no be solved with the Tune file. I have create a new database that distinguishes between ROMs that have same CAL ID but different hardware ID
If you have emailed me your original ROM and are still waiting on a working Tune File, please email me (shiv@vishnutuning.com) and i'll send you the new .dev file to upload! Cheers Shiv |
01-17-2014, 03:13 PM | #21 |
No 55mph
1622
Rep 8,477
Mounting solution?
01-17-2014, 03:55 PM | #22 |
Rep 734
This fits it perfectly and attatches to vent
http://www.amazon.com/Bracketron-PHV.../dp/B0014S5FVQ |
