01-17-2014, 03:04 AM | #1 |
Rep 363
Drives: 320d M-Sport, X1, 525d
BMW F30 Lowering Springs with MINIMAL DROP
This is probably my 3rd thread related to my F30 320D's suspension issue and I have come to a conclusion that I'll settle for just the springs for now as the coilovers lowers the car quite a bit and KWs and Bilsteins are too low for Indian driving conditions even on their highest setup.
Here is a pic which shows the ground clearance of an Indian spec F30. My car has the same suspension (base comfort) and I'm looking for a SLIGHT DROP (around 15-20mm from it's current height). From what I have heard, the H&R Sports makes the car too bouncy so I have shortlisted the following options; 1. M-Sport Suspension Springs 2. Dinan Performance Suspension System 3. Other |
01-17-2014, 09:09 AM | #2 |
Rep 4,321
Which part of India are you driving in?
I'd say keep it MPS because it'll give you apparently more clearance than the Dinan, which some are claiming is giving a 20mm drop off of the sport suspension (Dinan is 20mm off of the sport suspension)
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
01-17-2014, 11:42 AM | #3 |
Rep 363
Mumbai-Delhi with occasional trips by road with 3-4 people on board between these two cities... Heard that the MPS is too low and too stiff hence not too sure.
01-17-2014, 12:39 PM | #4 |
Rep 349
Maybe a sport suspension is the middle ground? I'm not sure the diff between that and luxury though. I guess just look at a sport and see if you like it.
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water. |
01-17-2014, 02:22 PM | #5 |
Rep 363
Guys, this is a VERY IMPORTANT QUESTION. There is someone selling the M Sport shocks and spring and we are on the verge of finalising. Will there be any installation issues if I get those? He only has the front and rear shocks plus springs. Will there be any fitment issues? If yes, what additional parts will I need? Once again reminding you all that mine's a base standard suspension. Here is the last 7 digit of my VIN: NP10090
01-17-2014, 03:45 PM | #6 | |
Rep 1,201
01-18-2014, 12:11 AM | #7 | |
Rep 4,321
01-18-2014, 12:59 AM | #8 |
Rep 363
01-19-2014, 10:00 PM | #9 |
Rep 4,321
Yes.
01-20-2014, 07:32 AM | #10 |
Rep 363
How about SPORT/M SPORT SUSPENSION SPRINGS on STANDARD SUSPENSION GUYS ? Shouldn't it be the best option? AFAIK, the M-Sport/Sport Suspension is only 10mm lower than the standard suspension and that's what I'm looking for.
01-20-2014, 11:44 AM | #11 |
Rep 1,136
you should get the whole setup (including shocks).
sent from bimmerpost Android app
01-20-2014, 12:16 PM | #12 |
Rep 363
01-20-2014, 12:26 PM | #13 | |
Rep 1,136
You are in a tough situation my friend, I wish I could offer more insight.
01-20-2014, 12:31 PM | #14 | |
Rep 363
PS: Your car looks fantastic. I was confused between Melbourne Red and AW and your car's snaps played an important role in me opting for the AW |
01-20-2014, 01:02 PM | #15 | |
Rep 1,201
If I'm not mistaken, your suspension looks significantly taller than the base US spec suspension. If I were to guess, your car has special shocks/springs to give a comfortable ride and raise the ride height. So that being said, going for a US spec M sport kit (springs/shocks) will probably drop your car a lot more than 10mm. From what I can see, I'd say 20mm-30mm. But the good thing is, the M sport springs/shocks should be plug and play. The only last thing I would recommend is that larger anti-roll bars that come standard with the sport/M sport cars in the US. If those are easy enough to purchase through BMW parts catalog, it'll be worth doing. Otherwise you'll have the stiff suspension but still lots of body roll. Though I suppose it'll still be better than base. Good luck! |
01-20-2014, 01:37 PM | #16 | |
Rep 363
The last option I could think off is buying the US spec front struts (standard), removing those spacers at the rear and replacing the springs with the US spec M-Sport/Sport ones |
01-20-2014, 03:28 PM | #17 | |
Rep 1,136
Thanks man!! Good to hear man, glad you went for AW. Car looks even better in person, pictures never do justice ha.
01-21-2014, 12:38 AM | #18 |
Rep 363
Won't the car be more comfortable if I install M Sport/Sport springs on the standard suspension rather than installing one of those Eibach/H&R lowering springs?
01-22-2014, 05:59 PM | #19 |
Rep 299
AC Schnitzer lowers less than H&R.
2018 991.2 GT3 MT Clubsport - 2016 Mercedes C450 AMG Sport break - 2015 Range Rover Sport SDV6 HSE Dynamic - 1993 BMW E36 M3 tracktoy - 1990 Porsche 964 Carrera 4 convertible
01-22-2014, 06:20 PM | #20 |
Rep 639
do it once and do it right! This is a 50k+ car. A suspension is worth 2-5k to do it properly. Cosmetic changes (springs only) are best for show cars or smooth driving conditions.
the best OEM suspension is the MPS. On your car m-sport ARB and new MP shocks/springs the best sport suspension is the one with DHP - not possible on your car the best sport suspension is sport shocks and sport springs along with m-sport ARB if you install H&R springs, dinan springs, Eibach springs, M-sport springs you are highly recommended to install the m-sport shocks AND ARB if you install H&R springs, dinan springs, m-sport springs or eibach springs on base suspension shocks and base ARB, you will not improve handling on all surfaces. on smooth roads you will improve a bit, but if there are rough patches on the road or you hit a bump in a turn, you will unsettle your car. if you install H&R springs, dinan springs, m-sport springs or eibach springs on m-sport suspension shocks but base ARB, it will be a better match, but you will notice the same amount of body roll. Again, possibly unsettling your car mid turn. |
01-09-2023, 01:26 PM | #21 |
Rep 2
New post and need some guidance
Hello guys.
I have a bmw f30 320d, I’m from Bangalore. I recently ordered for the cobra lowering springs with a 30mm drop. I had a few queries regarding the fitment and the safety of the car. Currently I’m running on 245/45/R18 OZ wheels and Continental contisport tyres. I just got the springs, I haven’t installed them yet. It’s gonna be a 30mm drop. Is there anything else I have to do? I’m currently running on a budget. This is gonna be a daily driver for the new few months. Any kind of advice is appreciated. Thanks in advance |
