How many oil are burn- consume your E90?
12-16-2005, 05:52 AM | #2 |
Rep 1,002
330i (07/05) About a litre every 5000kmīs (3000mls).
A little more in summer (full speed (155mph) on the autobahn in 5th @6400rpms for cruising burns more oil). A little less in winter (winter tires only rated to 132mph, so I max out at 135mph in 6th gear giving me 5300 rpms for cruising revs The N52 (as the M54 did too) does burn a bit more oil the higher you rev (especially if you run high revs for a longer time). But since the N52 can rev higher (7000rpm limiter vs. 6400 on the M54), it is capable of burning slightly more oil than the M54.
No, not THAT kind of tierfreund!
12-21-2005, 07:52 AM | #3 |
Rep 898
Drives: F90 M5
I've just had to add a litre of oil at 4630 miles on my Euro 325i. A little bit worried about the consumption at the moment, especially as I don't really gun it hard most of the time (although I do drive mostly in town).
01-04-2006, 12:31 PM | #4 |
Long Time Admirer, First Time Owner
18032
Rep 9,378
Just had to put a quart in at 8500 miles. Was a it worried when I opened the cap, and it smelled in there and was a bit smoldering. I think I'm getting a new filter and some Mobil 1 for the weekend.
01-11-2006, 07:12 AM | #5 |
Rep 1
Low oil pressure alarm
At 8500km's, got low oil pressure alarm when stopping engine (a couple of times), got cold feet.
Checked oil level - low. Phoned dealer who said ok to drive and get oil. On my way to the shop I finally got the low level alarm. Is this normal? Low oil pressure first, then low level and 1liter oil the first 8500km's. |
01-11-2006, 12:04 PM | #6 | |
Rep 898
Drives: F90 M5
04-27-2006, 12:42 PM | #8 |
Rep 1
Drives: 2006 325 Xi
i just went to the dealer, and they said it is normal to have to add i quart during the 15,000 mile service interval. I had the same worry but all is well
04-27-2006, 08:11 PM | #9 |
fresher den you
34
Rep 986
Drives: 2004 x3
i just added a quart to mine i have about 12k miles
