new wheel rubs my front suspession?
02-02-2014, 10:18 AM | #1 |
Rep 2,016
i just got my GF06's yesterday and had some trouble. my ONE front rim rubs against my suspession. what can i do? i run 19x9.5s all around. maybe just a 5mm spacers? since its only one maybe my suspicion is bent? and if it was will a spacer work because i don't feel like spending money on suspicion when i plan on lowering my car in the spring.
Instagram~~"alexverdii"~~~
02-02-2014, 10:38 AM | #2 |
Master Gunner
77
Rep 435
Drives: 2008 335i Sport
Which component is being rubbed? It certainly sounds like something may be amiss if only once side rubs. You need to carefully compare the geometry, shape, and mounting position of the suspect components with their opposite sides, as well as look for potential signs of an accident or damage.
Also compare the settled ride height between each side, such as from the ground to the apex of the fender wheel opening.
2008 335i Alpine White Sport Sedan AT | Avant Garde M364 Staggered 19"
02-02-2014, 10:50 AM | #3 |
Rep 471
Maybe these wheels just don't fit your car, if your thinking you need spacers then you are forcing an application that was not meant for your car.
-Kevin |
02-02-2014, 10:56 AM | #4 | |
Rep 2,016
02-02-2014, 10:57 AM | #5 | |
Rep 2,016
02-02-2014, 11:23 AM | #6 |
Master Gunner
77
Rep 435
"The metal bar about the brakes..." Hmm, I'm still not sure what you are referring to.
With the brakes to the rear of the front suspension, the only "bar about" the brakes is the lower control arm (item 14 in the parts diagram), which is nigh impossible for a wheel to contact, unless severely deformed rearwards, which would be very noticeable and likely undriveable: But there is a tension rod in front of the suspension that might contact a wheel if it's bent, item 9 below: The tension rod is a common component that can get damaged or bent under duress, such as hitting a nasty bump at speed. It's bushings and/or ball joint could also wear or get damaged resulting in more play that can cause wheel contact.
02-02-2014, 11:27 AM | #7 |
ALL RIGHTY THEN
222
Rep 2,957
you said you have a square 19x9.5 setup but are they all the same offset?
BMW CCA Member 483866
02-02-2014, 11:28 AM | #8 |
Rep 2,016
30 and 33..i switched them all out to see if i had them mixed up but no luck
02-02-2014, 11:29 AM | #9 |
Rep 2,016
https://encrypted-tbn2.gstatic.com/i...m3DwwF_WWOrBMA
not my car but that rod...believe its the strut
02-02-2014, 11:37 AM | #10 |
ALL RIGHTY THEN
222
Rep 2,957
if you get spacers for the front, you then may run into the possibility of rubbing against the fender. may work but i've never run 9.5 in the front before.
02-02-2014, 11:38 AM | #11 | |
Rep 2,016
02-02-2014, 11:40 AM | #12 |
Master Gunner
77
Rep 435
Wow, I've only encountered strut contact issues with current model F-150 4x4's using strut spacers for lift combined with certain 10"+ wide rims and certain offsets...
You may want to get your camber checked, comparing the left and right sides. Certainly your rim offsets are borderline and any suspension geometry issues can result in your predicament... And lowering your vehicle will definitely exacerbate the problem.
02-02-2014, 11:43 AM | #13 | |
Rep 2,016
02-02-2014, 11:50 AM | #15 |
Master Gunner
77
Rep 435
Yes, but as Dan mentions, it could cause fender lip issues with your 19x9.5 rims, depending on tire profile. The manufacturer certainly used more positive offset to push their 9.5" wide rim inboard; I've got 19x8.5's up front and rim lip is about flush with the fender opening.
Again, lowering with spacers may cause fender lip issues if you don't experience them at stock ride height.
02-02-2014, 12:15 PM | #16 |
Rep 131
OP,
Everyone is offering you the best solutions. Go get your alignment checked, check for bent suspension components, double check your wheel size and offset. You just keep referencing spacers...... That it not the best solution but if you want to coverup potential issues with the cheap way out? Go for it |
02-02-2014, 12:18 PM | #17 | |
Rep 2,016
02-02-2014, 12:55 PM | #18 | |
Master Gunner
77
Rep 435
Yes, you will definitely have to realign the car after coil installation, but trying to save money on duplicate work (e.g. alignment) in this potentially disastrous issue by performing modifications first that will amplify the problem is not the most sound and recommended method, and could result in spending much more money than necessary over first resolving the contact issue. If you discover any bent suspension components after your coil install and alignment, you still will need to have it realigned after replacing the damaged components, so the net result is the same: money spent on multiple alignment jobs. As the saying goes, "You can pay me now, or you can pay me later." But hey, it's your car and I've provided all the assist I can. Good luck!
02-02-2014, 12:56 PM | #19 | ||
Rep 2,016
02-02-2014, 03:26 PM | #20 |
Rep 5,120
02-02-2014, 03:39 PM | #21 |
Rep 2,016
I think I had the 30 in front. But I took them off and going to a Indy.
02-02-2014, 05:59 PM | #22 |
Rep 1,509
Get an alignment and go from there first.
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior |
