E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > DPF removal
Reply
      02-02-2014, 01:03 PM   #1
verde
E30 Obsessive
verde's Avatar
Drives: E21,E30,E36
DPF removal
This may be a silly question but wel see. I do huge mileage and with it now being an MOT failure to have no DPF would it be worth my while removing it?
They do get blocked/knackered and theyr very expensive replace. Would it be sensible to have a delete pipe made to give me a bit extra go and then come MOT time I can put the DPF back in?
I know there is controversy surrounding removal. What seems to be the general consensus on it these days?
E21 316i + E30 340i + E36 318TI Dakar
BMW I car sales exec [00=[][]=00]
      02-02-2014, 01:15 PM   #2
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
United Kingdom
462
Drives: BMW M4 Competition
If your doing lots of miles and the DPF is giving no trouble then I'd leave it alone....
Scott
2018 BMW M4 Competition
2019 Mini Countryman Cooper S : 2008 Mini Cooper
      02-02-2014, 01:21 PM   #3
verde
E30 Obsessive
verde's Avatar
Drives: E21,E30,E36
Not worth saving it for MOTs?
      02-02-2014, 02:43 PM   #4
90MSP
Drives: 330D M Sport
I'd leave it in place. I went through this recently with a partially blocked DPF, after weighing up the implications... MOT inspections...potential sell on issues... etc decided it's a hassle thing to maintain, but potentially cheaper and less hassle than if I removed it.
      02-02-2014, 02:45 PM   #5
DMH-01
DMH-01's Avatar
12
Drives: E92 335d M Sport
If it ain't broke, don't fix it
      02-03-2014, 06:43 AM   #6
E91-Gaz
Drives: 2010 E91 318d
If you want a bit of extra oomph then i say go for it, i doubt you'll even need to refit it come MOT time but if you do it's not a hard job on the 4 cylinder diesels unlike the 6 cylinders. Hardest part was seperating the existing dpf from the mid section but once it's done once it shouldn't be too much of an issue in future. And as you say keeps your DPF in good condition.
HTH
      02-03-2014, 09:30 AM   #7
verde
E30 Obsessive
verde's Avatar
Drives: E21,E30,E36
HTH
Youve understood the idea 100% man. The oomf doesnt worry me, but keeping it in good MOT - passing nick IS a worry. Theyr an absolute fortune to replace and the age of the car and the miles I do itl be sooner rather than later I imagine. Would it be quite simple to just put a delete pipe in then refit it come mot time? Would I need the warning light coded out whilst it was out of place? And would it endanger the motor?
      02-03-2014, 10:56 AM   #8
E91-Gaz
Yes you would still need to have it remapped to stop the engine trying to undertake the regen.
Yes it's not a dificult job to do on the 4 cylinders once the undertray is off theirs few bolts to undo which really which arent that hard to access either and then seperate the DPF from the mid which could be easy or it could be a pain vehicle dependant.
Have a chat to Ecotune. They're based in Glasgow. Look out for a group buy on one of the forums you can get as much as 20% off one of their DPF delete kits.
HTH
      02-03-2014, 12:56 PM   #9
DavS1
DavS1's Avatar
Scotland
53
Drives: Emfree
2011 BMW M3  [0.00]
Why not cut the DPF open, smash the insides out, weld in a straight pipe, then weld the cover back on the DPF so it "looks" standard.....not like their going to remove your exhaust to check it for MOT
http://www.e90post.com/forums/signaturepics/sigpic97427_1.gif
Monte Carlo Blue M3 Comp
      02-03-2014, 05:03 PM   #10
ukbeemerboy
Beemer Heaven
United Kingdom
462
It's short journeys that kill the filters, not doing higher milages. As said before, if it ain't broke then don't fix it. Sounds like your going to open a can of worms and a load of hassle every year come MOT time.
Do you actually have a DPF problem?
Scott
      02-04-2014, 02:40 AM   #11
E91-Gaz
How's it hassle as already stated its a simple swap on the N47 nothing to remove to get to the DPF except for the undertray?!?
      02-04-2014, 02:53 AM   #12
ukbeemerboy
Beemer Heaven
United Kingdom
462
Because if it's left alone you don't need to touch it at all
Scott
      02-04-2014, 03:07 AM   #13
E91-Gaz
Until it blocks at which point it could be mega bucks but each to their own
I wanted some more power too so as I was getting it remapped anyway I thought it would be rude not too....
For info at MOT time mine blew 0.03ppm the limits is 1.5ppm the machine couldn't even detect that the engine was being revved with the exhaust probe so they had to connect a cable to the battery terminals to detect the increase in RPM.
HTH
Reply
e90post
