Service Engine Soon light came on?? 50k miles
02-03-2014, 07:54 PM | #1 |
Rep 78
This light just came on and I am new to BMW. I have about 50k miles on.
The computer shows everything to be OK. What does this light mean? Car seems to drive fine. Not the oil change but the Engine Service shows about 2700 mls left. |
02-03-2014, 08:01 PM | #2 |
Борис
31
Rep 505
Get the codes read and go from there.
Otherwise, its all speculation, especially with the detailed description that you have provided us.
07 SG 335i GONE!
COBB - Burger Motorsports -Ultimate Racing - Evolution Racewerks - TiAL- AMS In Winter Mode - Dunlop Wintersport 3D/Sport Edition Wheels |
02-03-2014, 08:34 PM | #3 |
Rep 205
Pep Boys does free OBD code readings, you can have them check it out and tell you.
2011 E90 328i | CDV Delete | BMW PE | Bilstein B12 Pro-Kit | 17x9 ET30 APEX ARC-8's | 255/40
02-03-2014, 10:15 PM | #5 |
Rep 205
As far as I know, Autozone does not do code readings anymore. Maybe O'reilly auto parts does.
02-03-2014, 10:48 PM | #6 |
Rep 376
My guess is Routine service. I remember going in for 50k service.
They checked to see any problems with car. Ended up switching out wiper blades and refilling wwasher fluid. Oh forgot about full detail service. |
02-04-2014, 09:25 AM | #8 |
Rep 10,120
02-04-2014, 11:30 AM | #9 |
Rep 78
02-04-2014, 11:41 AM | #10 |
Rep 10,120
I couldn't tell you but when I had a 328 mine went at around 40k miles. It was under warranty though. The sensors shouldn't be too hard to replace I'm sure there is a DYI somewhere on it. Might just be a bit of a bitch to get to them.
02-04-2014, 11:54 AM | #11 |
Rep 10,120
02-04-2014, 12:36 PM | #12 |
FSAE Dude
62
Rep 759
im pretty sure it just means it's time for BMW inspection 2
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA |
02-04-2014, 02:40 PM | #14 |
Rep 10,120
02-04-2014, 03:56 PM | #15 |
FSAE Dude
62
Rep 759
02-04-2014, 05:14 PM | #16 |
Rep 1,834
Drives: '05 E90 330i Manual
I would start by going through the service menu to see if anything comes up, could be a time or mileage based service item. If of course nothing comes up there, then have the codes read...
02-18-2014, 11:19 AM | #17 | |
Rep 466
1. O2 sensors you have 4 if so replace them all the same time 2. Vanos selenoids in front of the car easy but expensive 3. Coil plugs need to be replaced might as we'll replace all as well |
02-18-2014, 12:22 PM | #18 |
Guest
Rep n/a
Drives:
What are you talking about dude?
Your car only has 50k miles you don't need to start replacing a bunch of stuff like that till 100k. The o2 sensors have a expected life of around 140k miles, one of yours failed early no need to replace all 4. Just replace the o2 sensor the part is around $50, find a independent BMW shop to do it for you. And I would check with a dealer first to see if its covered, I know in California it should be covered under the extended emissions warranty we get. |
02-18-2014, 12:47 PM | #19 | |
Rep 10,120
If anything replace the spark plugs and clean the VANOS solenoids. |
02-18-2014, 11:14 PM | #20 | |
Rep 466
