BMW WHAT !!!
02-07-2014, 11:49 AM | #1 |
Rep 181
Drives: 330D M Sport
BMW WHAT !!!
I ran the BMW What diag app today against my car. To my horror it detected the below fault codes
I will try a reset but is there anything here to really worry about ? Fault Report - BMWhat - Version: 9.26 ID1: e4b8f140-78d5-4e51-9744-feb65878307b-876ID2: 5f54982f-8617-48a4-a34f-93835c767231-bb8 INFO: 0D0BC9B8A7A3867C665C473727179 Base: E90 Faults: 12 ECUs: 16 Model: 330 d M 57 3 06 D3 Battery: 15.0V Normal communication Normal connection Date: 2014-02-07 07:10:13 OBDII Version: 18 ABS / DSC / Brake: Dynamische Stabilitaets Kontrolle / DSC Fehler: Speed Sensor Front Right / Gyroscope / Drivers exhaust (dump) shorted right front Code: 5DA3 Fehler: Speed Sensor Front Left / Valve relay / Coil inlet valve (ISO) open front right / Valve relay: Medium-or high-resistance short-circuit Code: 5D93 Fehler: Pressure sensor is defective right / Valve HSV2 / ECU internally: BIST error Code: 5DCC Fehler: Pressure sensor defective left rear / Valve UPS1 / Valve USV1 / Illegal state Code: 5DBC Fehler: Steering angle sensor sensor error F-CAN / Message F-CAN Code: 94BD Instrument cluster: Instrument cluster / Kombiinstrument Fehler: CAN signal fault DSC Code: A3B9 Fehler: Failure of tank-level raw data Code: A54C Immobilizer System: CAS Fehler: Signal detection error rate Code: A0B5 Fehler: CAS Supply Error Code: A0B2 Systems: Junction Box Passenger / Beifahrer Fehler: PT-CAN communication / PT-CAN communikation Code: C90B Fehler: FONDSCHICHTUNGSPOTI / unknown failure Code: 9C69 |
02-07-2014, 12:38 PM | #2 |
Rep 192
When was the data last cleared? Could be an intermittent connection problem, I would advise clearing it and see which if any come back over a given time, keep a record of what you find. Most of the codes are linked to DSC so have you had any warning lights come up? The A0B5 isn't uncommon to see when plugged into the BMW ISTA kit. Unfortunately with your kit you can't see when the fault last occurred etc.
Hope that helps a little? |
02-10-2014, 10:46 AM | #3 |
Rep 181
Cleared them all, 3 days later these returned:
ABS / DSC / Brake: Dynamische Stabilitaets Kontrolle / DSC Fehler: Speed Sensor Front Right / Gyroscope / Drivers exhaust (dump) shorted right front Code: 5DA3 Fehler: Speed Sensor Front Left / Valve relay / Coil inlet valve (ISO) open front right / Valve relay: Medium-or high-resistance short-circuit Code: 5D93 Fehler: Pressure sensor is defective right / Valve HSV2 / ECU internally: BIST error Code: 5DCC Fehler: Pressure sensor defective left rear / Valve UPS1 / Valve USV1 / Illegal state Code: 5DBC Fehler: Steering angle sensor sensor error F-CAN / Message F-CAN Code: 94BD So pressure and speed sensors plus steering angle !... should I lose sleep ? |
02-10-2014, 03:45 PM | #4 |
Rep 192
The steering angle sensor is a separate control unit, but signals through the dsc control unit on your age of car.
If your not having warning lights come on then it's probably not worth worry about, it would be a spurious message which is logging in the fault memory but only occurring for a minute period that it isn't causing a problem. There are several codes that come up due to software glitches etc. If you are having warning lights appear etc my gut would say its a DSC control unit failing. |
02-10-2014, 04:40 PM | #5 |
Rep 181
Thanks, appreciate the input. No warning lights..... so i'll go to bed
02-17-2014, 02:29 PM | #7 |
Rep 5,050
