Why isn't the selected gear displayed on the dash for manual gearboxes?
02-11-2014, 01:38 PM | #1 |
Rep 313
Is it as you can tell which gear you are in for manuals (position of gear lever) whereas for automatics it's slightly harder?
02-11-2014, 02:05 PM | #6 |
Rep 9,097
Enlighten us
AFAIK, its few limited cars which can have it coded. Majority are exclusions. Question to OP, why would you like to know what gear are you in? Surely you are changing it and not the passenger.
02-11-2014, 02:07 PM | #7 |
Rep 3,200
Drives: E92 325i MSport Coupe
I turned mine off! I think it's press and hold the button on the end of the left hand upper stalk if I recall...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
02-11-2014, 02:49 PM | #8 |
Rep 108
Shift indication can be coded but actual gear can't is what I meant to say, the gearbox on a manual doesn't have individual sensors for each gear. Enlighten me if I'm wrong.
02-11-2014, 02:53 PM | #10 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
That's right, although the car obviously knows what gears it's in to suggest its next shift either up or down, which was part of the efficient dynamics.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
02-11-2014, 02:55 PM | #11 |
Beemer Heaven
462
Rep 2,941
Yes plus engine load and throttle position....
Scott
02-11-2014, 02:56 PM | #12 |
Rep 108
02-11-2014, 03:00 PM | #13 |
Beemer Heaven
462
Rep 2,941
That's a good point, it's probably worked out by RPM in relation to the speed your doing.
Scott
02-11-2014, 03:17 PM | #14 |
Rep 966
It knows. arrow up or down as needed. E.g. 5^
Can be coded on most cars. I have may 07 which is only a while i think after ED was launched on the smaller engines |
02-11-2014, 03:25 PM | #15 |
Rep 108
02-11-2014, 04:07 PM | #16 |
Beemer Heaven
462
Rep 2,941
We have it on our R56 Mini Cooper and it gives the arrow and the gear number your currently in.
Scott
02-11-2014, 04:12 PM | #17 |
Rep 838
Drives: LCI M135i
Mine gives me the gear number too. 2007 e92 320d.
