Is this lifter noise? It's too loud to be injectors *video*
02-12-2014, 09:49 PM | #1 |
Rep 84
Car is a 2009 335i and I get normal injector noise but at times I get this awful loud ticking and it comes and goes. I can't get it to replicate everyone I took it to the dealer so they keep telling me it's injectors but what they hear hasn't been what you hear in this video. Opinions?
02-13-2014, 12:13 AM | #2 |
Rep 13,128
Yep
Yep see sticky at top of page.
http://www.e90post.com/forums/showthread.php?t=13504 its not to bad yet . |
02-13-2014, 03:40 AM | #4 |
Rep 665
That's a sticking lifter. Had the same issue myself recently and, at least so far, have cured it by adding a little over half a can (10 oz or so) of CRC motor treatment to the oil once it was warmed up, letting it idle for 15 minutes, and then changing the oil/filter with Castrol Edge 5W-40. I don't know if the motor treatment did anything since I was a bit nervous because of the turbos and didn't drive the car for 30-60 miles as they suggest. It may have been that the solution was simply switching from Mobil 1 0W-40 to Castrol Edge 5W-40 (which is also LL-01 approved). Regardless, I haven't heard the random lifter noise for a while now.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
02-13-2014, 12:22 PM | #6 |
Rep 2,049
its normal, all N54s do that. its called an evap release valve. when u blip the gas it goes away.
I was trippin when i first heard that sound too, did a bunch of research. it comes after a long drive and let the car idle. I took it to the dealer and replicated it for them and they agreed something was wrong until the next day they called me and told me what it really was. even tho I still dont like how it sounds if u do enough research, you realize that all N54s make that sound n54s are loud engines, if u want a quiet one buy a hybrid lol FIRST POST YEAH! |
02-13-2014, 12:23 PM | #7 | |
Rep 2,049
02-13-2014, 01:14 PM | #8 |
Rep 3,732
Drives: BMW S1000XR
I am speechless.
BMWCCA member |
02-13-2014, 05:30 PM | #9 | ||
Rep 84
02-13-2014, 05:31 PM | #10 | |
Rep 84
Multiple times and it's never happened while with them so they keep telling me it's normal injector noise but it's absolutely not |
02-13-2014, 05:58 PM | #11 |
Rep 2,049
The sound wont come on if you just start up the car and idle it
this is what you have to do... Take the tech or SA with you on a test drive then park it and let it idle for 30 sec and it will tick for sure...dont shut the engine off then turn it back on and expect to hear that ticking sound because that is probably what you did. if you google, "N54 ticking after drive" you will see a thread from 1addicts about it and everyone has the same sound. I know BMW owners are really anal about things so if it makes you feel better go ahead and do it otherwise just chill out cuz its normal I really dont like the way it sounds either, everytime i hear it i blip the throttle. if you really had any major issues im sure it would be obvious and affect performance or throw some codes |
02-13-2014, 06:00 PM | #12 | |
Rep 2,049
02-13-2014, 06:01 PM | #13 |
Rep 2,049
02-13-2014, 06:54 PM | #14 | ||
Rep 84
02-13-2014, 07:19 PM | #15 |
Rep 2,049
dude its normal! im 99% sure! lol trust me it sounds just like mine even when i had 15k on the Odometer
Your not smarter than those several BMW dealers that told you its normal me and my boy both have 335s and both make that noise. its called the evaporation control valve. if it goes away once u blip the throttle its nothing bad. if it was some kind of mechanic ailment, the sound would get louder as you hit the throttle. why dont u do some research or even click on the link i gave you |
02-13-2014, 09:01 PM | #16 | |
Rep 84
02-13-2014, 09:03 PM | #17 |
Rep 13,128
Isn't that video proof enough?
Strange that its on a 335 . I would record it several times put the recordings on a CD or usb drive and show them that . People like to take pictures of the date on a newspaper to validate the date plus I bet this happens mostly on the first start of the day. |
02-13-2014, 10:20 PM | #18 | |
Rep 84
02-13-2014, 10:24 PM | #19 |
Rep 2,049
im pretty sure they are gonna say its normal.
give us an update after you bring it in.. and if we dont hear back from you we can finally conclude you were incorrect http://www.1addicts.com/forums/showthread.php?t=730524 |
