ECU conector
02-12-2014, 11:04 PM | #1 |
Rep 791
Drives: 2011 550xi
ECU conector
So you know how in the JB4 install video they tell you NOT to re-install the ECU sub harness connector without the clips? Well mine popped out right as I was installing it. And now the stupid thing wont come back off. Im speculating it's now permanently attached! Which is ok, but I forgot to put my SLD in. And when I sell the car some day I'd like to pull the JB4.
So, has anyone had this happen? How do you remove the connector to re-insert the clip?
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE |
02-13-2014, 03:10 PM | #3 |
Rep 791
Drives: 2011 550xi
Really? I tried and there was nothing to engage in the hole.
02-13-2014, 07:53 PM | #4 | |
Rep 1,023
You click hose holes (there are 2 per side. Pretty sure you so the ones closest to the outside) once it's off. If it's still stuck on then something is wrong you just slide the slider off |
02-13-2014, 09:46 PM | #5 |
Rep 791
Drives: 2011 550xi
Still on. The slider is completely out. The connector is directly on the ecu and will not pull off.
08-19-2014, 01:44 PM | #6 |
Rep 541
Bump! OP did you ever figure out how to remove it? I have this same problem!
Now: 2012 F30 335i / 6MT / JB4 / ER Catless DP
Sold: 2010 Jeep GC SRT8 Sold: 2007 E90 335i / 6MT / JB4 / Vishnu Exhaust / VMR 710 19" / BMS DCI / HKS Blow Off Valve / Tinted Tails / Clutch Stop |
