Low Engine Oil Light Came On?
02-15-2014, 02:35 AM | #1 |
Rep 120
A couple nights ago, when I started up my car, I wanted it to warm up a little first before driving off. After a few minutes, a Low Engine Oil light warning message came up, saying that it is not safe to continue to drive this car. I went into the car information screen and ENGINE OIL had a green OK next to it.
I just had the oil changed around 6 months ago, ~4k miles ago at Stevens Creek BMW in San Jose, CA. The HPFP and the low side fuel pressure sensor was also changed around the same time. I proceeded to turn off my car, and did a visual inspection around. No leaks on the ground as the quick google search on my phone said. After a few minutes of the car being off, I turned it back on, and the warning message flashed once before turning off. Has anybody had this issue? Should I be worried? Thanks, Alan |
02-15-2014, 05:05 AM | #3 |
Rep 60
Drives: E92 325i 2007 sgm
Your not meant to leave the car ticking over to warm up, read your owners manual it warns about this, so maybe this is the reason your getting this warning, ie your not building enough oil pressure whilst ticking over. try driving your car instead of leaving it to warm up
02-15-2014, 05:07 AM | #4 |
Rep 739
Had the same exact problem 2 days ago. Started the car, low oil light came on, drove out to buy a qt. of oil., I come out start the car and the light is gone :P I just want to believe it was the cars system malfunctioning like it does from time to time on random things like the temp.
2009 Alpine White E92 N51 328i Automagic | Premium & Sport Pkg. | Coral Red/Black Dakota Leather Interior | M-Spor | BMW Performance Exhaust | Active Autowerke Headers | BBS CH-R | CPS Front Lip | Performance Front Grills | 888Concepts Custom Headlights (GONE)
2011 Alpine White E90 N55 335i Automagic |
02-15-2014, 08:56 AM | #5 |
Rep 1,132
Condensation on the sensor can and will cause such issues, i suggest taking the car for a drive until it reaches full operating - oil temp and then checking it, moisture wreaks havoc on the oil sensors in these cars.
02-15-2014, 11:19 AM | #6 |
Rep 13,128
Start monitoring the graph
the idiot light will only warn you when things are going way bad. You don't know how full it was when you left the dealership so you have no idea if it lost a little oil or a lot. The oil sensing system they have in this car is quirky and is no substitute for a dipstick which is now offered as 250 option on the newer car. |
02-15-2014, 01:50 PM | #7 | |
Rep 60
Is there any way of fitting our cars with a dipstick? |
02-15-2014, 09:34 PM | #9 |
BMWCCA 149159
38
Rep 847
The sensor is dual use as in sensor level indicator and temperature sensor. As such it reads the capacitance of the oil and when you get condensate it changes what that capacitance should read and throws a code.
That is why at times changing the oil corrects the problem. Hard to say that is your issue but do you have that issue if you drive at highway speeds for an hour? They would flash all the condensation out... |
02-15-2014, 09:42 PM | #11 | |
Rep 120
02-16-2014, 06:41 AM | #12 | |
Rep 18,808
The capacitance of the oil is temperature dependent, so the oil sensor also has a temperature probe to determine the temperature of the oil. Once the oil is at operating temperature the capacitance data is then used by the CBS to determine the oil level. I believe that you let the car idle a bit too long at start up as a previous Poster said. Also upon start up the system shows the previous oil level reading until the system makes a new reading. Last edited by Efthreeoh; 02-16-2014 at 06:52 AM.. |
02-17-2014, 01:36 AM | #13 | |
Rep 848
Drives: '01 E39 540iA, '09 E90 M3
E90 M3 DCT LCI | E90 LCI N54 M-Sport(retired) | E90 Technical Docs download: http://j.mp/bmwe90docs *good read, very detailed.
02-17-2014, 05:11 AM | #14 |
Rep 18,808
No. The "OK" message means there is sufficient oil to operate the engine. The E90 has two oil level reading messages 1) a static level reading that says "OK"; 2) a bar graph that represents the percentage of the top (7th) quart of oil.
02-18-2014, 03:01 PM | #15 | |
Rep 848
