Driving from nyc to texas???
02-18-2014, 08:01 AM | #1 |
Rep 99
Ok so me and the family are making the move to dallas tx. We both have to bring our cars so we decided to just drive it. I only had my car since december and have not had any issues with it other then a 29E2 code after i installed jb4 and did a 3rd gear map 5 pull. i restarted and that code became a shadow code and never popped up again. Other then that my front tires are a little worn but still somewhat manageable. I currently have 79k on the dash. Do you guys think i might have any issues? Are these cars usually good for long distance road trips?
02-18-2014, 08:37 AM | #2 |
BD_e92
358
Rep 1,748
You should be fine especially if you are just cruising speed and not beating on it the whole way there
Edit: Definitely get your tires checked/changed Last edited by BD_F22; 02-18-2014 at 08:58 AM.. |
02-18-2014, 08:48 AM | #3 |
M-GAM3
240
Rep 1,264
Why would you drive any where that far on worn tires? your asking for trouble if it rains are if you have a blow out from a small screw on the road. Hit up Ebay are check online for some tires. Better safe then sorry.
Car Enthusiast.
02-18-2014, 09:01 AM | #5 |
Rep 59
I have driven from VA to Dallas and at the end of the month I'm driving from VA to San Diego, CA. Get as much maintenance done before starting the trip, it's a lot easier getting those things done in an area you are familiar with.
Just as with any other car: -maintenance up to date -check fluid levels -top of washer fluid -check/replace wipers -check/replace serpentine belt -check/replace pulleys -inspect tires and pressure -check brake pads Unknown: -water pump -starter -hpfp Misc: -quart of oil -no spare tire, I keep a plug kit in the trunk and a small 12v air compressor. -have some safety equipment; flares, reflective triangle, flashlight, -charged cell phone -radar detector -first aid kit Good luck and safe driving. |
02-18-2014, 09:06 AM | #6 | |
M-GAM3
240
Rep 1,264
Car Enthusiast.
02-18-2014, 11:04 PM | #10 |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
Wow! Is your 335i really SO unreliable that you're worried about driving it just 1500 miles from NYC to Dallas?
That's nothing. I've driven U-haul trucks (which are are usually pieces of sh*t) multiple times across country without ever having a problem. I've ridden motorcycles thousands of miles to the Rockies and back, up to Canada and back and down to Mexico and back without any mechanical difficulties whatsoever. I've also driven my old Jeep TJ and my FJ Cruiser thousands of miles through the desert and through the mountains OFF ROAD without any mechanical troubles either. And, you're worrying about driving a mere 1500 miles on paved roads from NYC to Dallas? If that's the case, sell the car and just take a bus or plane and buy another 335i when you get to Texas. Otherwise, just make sure the car is mechanically sound before you start the trip and GO! No need to change the oil or do any other "normal" maintenance, if it's not due to be done w/in the anticipated mileage for the trip. Just check the fluids and check the air in tires and look for any punctures or sidewall damage. If there's no damage to the tires and low tread markers aren't visible on your tires yet, there's no reason why they shouldn't be able to make it another 1500 miles. But, if you don't have a spare, it would probably be wise to buy and carry a spare tire/jack kit AND sign up for AAA (or any other emergency car service you like) just in case you do have problems along the road. If your flashers work, triangles, flares and other road hazard warning devices really aren't necessary. However, a 1st aid kit is always good to have in the car. No need to buy a pre-made kit; you can put one together yourself w/what you have in the house. If you're traveling alone at night, a handgun also would be nice to have BUT there are legal issues about carrying a concealed weapon in a car. An RV would be different. So, if you are transporting a weapon in the car, read up on the legal issues and do so at your own risk. However, since you're from NYC, I assume the you do not own one given the gun control laws there. I assume you have a cell phone but there's always a chance there will be no cell coverage if and when you break down. Only a SAT phone can help in that case. I've got one for off-road use but most people don't have or want to spend the $ for one. You can rent one but, as long as you stay on major roadways, if a cop doesn't show up first, someone will usually stop and help you. Bueno suerte y buen viaje!
2008 Black Sapphire 335i E90 Sport & Premium Pkgs - Cobb Stage 1+FMIC Sport map, Mishimoto FMIC & Alpina B3 AT Flash. See: My Build Thread.
02-19-2014, 02:40 AM | #11 |
Rep 2,136
My brother drove from VA to Mexico City... Twice... One time was with a 1998 Kia Sphia with 175k miles and second time was with a 2000 Mercury Sable with 150k miles with no issues. Don't worry, your car won't self destruct.
02-19-2014, 05:06 AM | #12 |
Came to the N55 Darkside
1115
Rep 12,740
Yea, definitely get those tires- for your family- and for others around you!
Good luck, and hopefully your HPFP doesn't eat it along the way |
02-19-2014, 08:31 AM | #13 | |
Rep 447
02-19-2014, 09:14 AM | #14 | |
Rep 722
Drives: 2008 BMW 335xi
The unknown part is just living with the N54. Dunno when those are gonna go out, but if you have no symptoms now you should be fine. Starter is NBD, if you got a 6MT. |
02-19-2014, 09:27 AM | #15 |
Rep 140
I guess I am in the same boat. What kind of symptoms should I look for on a failing water pump and hpfp?
I am going to TX next month and would like to take the BMW but I don't want to run the risk of a huge repair bill miles away from home. |
02-19-2014, 09:34 AM | #16 | |
Rep 722
HPFP, long cranks to start.. Not a lot to go on, but I'm sure others will chime in. |
02-19-2014, 09:39 AM | #17 |
Rep 99
I get a slight shake at idle. rpms do not change and it is only like every 5-10sec i feel it. once i accelerate it goes away. i assumed this was just how the n54 is or maybe i need a walnut blast.
02-19-2014, 09:44 AM | #18 | |
Rep 38
Also, have a good rest, don't drive overnight or if you feel sleepy - this can become very dangerous. I drove my 8 yr old Nissan Maxima from Albany NY to Dallas few years ago - no problem, in fact it was a good opportunity to see places. This year we took 328 from Dallas to DC and back - great drive, very pleasant, no problems whatsoever. Welcome to Texas! :-) Last edited by Trespassers W; 02-19-2014 at 09:48 AM.. Reason: edit |
02-19-2014, 09:47 AM | #19 |
M-GAM3
240
Rep 1,264
From what i have been reading on the Forums if you are over 45000 miles and have not done a walnut blast yet then you need to. That might solve your hesitation problems but it will not have any impact on you taking it on a long road trip.
Car Enthusiast.
02-19-2014, 10:40 AM | #20 |
Rep 1,040
Made the drive from Boston, MA to Austin, TX in a stage 2+ Audi S4 with 105K miles AND with a 95 Chevy Tahoe LT with 220K miles pulling a trailer. I think you will be fine.
02-19-2014, 10:45 AM | #21 |
Rep 1,356
you should be fine as long as your car is well maintained. Get the steelie. Idk why they didnt put a damn spare tire in these cars.
Have fun driving and watch out for changing speed limits in different counties!!! |
02-19-2014, 11:08 AM | #22 |
Rep 447
Check your fluids and drive, and maybe 2 new tires.
I've driven across country in a beat-up Ford Tempo with 140k miles at the time. It's an ultimate driving machine, treat it like one |
