Which VIN number to use for FSC code post CIC retrofit??
02-19-2014, 01:29 PM | #1 |
Rep 3,295
So post install of my CIC retrofit I fancy updating the 2010 maps to 2014....
Now I have problem I'm not sure which VIN code to use to generate the FSC code needed to activate the navigation. The CIC unit is wired in with a hardware emulator which I think (could be very wrong) fools the CIC unit into thinking my cars VIN is the same as the VIN stored in the CIC unit. I've managed to pull the VIN from the CIC unit, and pretty sure its the right VIN code from the donor car. Looking up the VIN code online it looks like the donor car was fully loaded, and as expected had Combox installed, since pre-coding to my car the CIC unit was displaying all the BMW apps/online stuff associated with a Combox .... So I presume I need to use the VIN code from the CIC unit (ie: NOT my own VIN code) to generate the needed FSC code to enable map upgrading Any help really appreciated!!! |
02-20-2014, 05:46 PM | #4 |
Rep 1,945
Drives: 2011 335xi Msport, Conv, Tech
You use the vin off your car....
You don't get more than one vin on a car unless it's a parts car or a stolen car....
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
02-21-2014, 03:59 AM | #8 |
Rep 3,295
You can pull the vin using Tools 32. Load profile 00SWTKWP, and than the job FAHRGESTELLNUMMER_Lessen
The vin from the CIC is than displayed under FG_RN I found a guide about it somewhere on the interweb. |
02-21-2014, 04:26 AM | #9 |
Rep 5,050
The only Tool 32 I have fits on a 1/2" ratchet & I'm not sure that's gonna do the job
02-21-2014, 04:52 AM | #10 | |
Rep 219
Thats correct, you need the Cable Ian, whole new world of confusion when you do |
02-21-2014, 05:12 AM | #11 |
Rep 3,295
+1 Go for it, it's a bit scary at first, given all the software is in German, but than you quickly realise the car is basically one massive computer, well several. Plenty of info on how to get started around, and it's quite good fun....though unlike most computers if you mess something up you cannot just turn in on/off
02-21-2014, 07:45 AM | #12 | |
Rep 5,050
02-21-2014, 08:25 AM | #13 |
Rep 2,022
Don't play around using Tool 32...... only use if you know what you're doing - as one wrong click, you could seriously fuck up your car!
I haven't tried using it yet, not needed to........ |
02-21-2014, 09:15 AM | #14 |
Rep 5,050
I tend to agree, it wouldn't be the first time that I've done something to trash the computer but at least that only means another all nighter sorting it out, but pushing my BMW 250 miles to Makkan001 BMW is something else entirely
