02-26-2014, 12:19 AM | #1 |
Rep 463
Jb4/DP
Everytime I'm on the freeway and just flooring it, pushing it really hard, shifting around 6k.. Jb4 throws me into limp mode. And today I actually got "transmission malfunction" along with my drivetrain malfunction. Anyone know anything about this?
02-26-2014, 07:10 AM | #2 | |
Rep 586
02-26-2014, 09:46 AM | #3 |
Rep 1,252
i had drivetrain malfunction when floored it 3k rev till 130-140mph in 6th gear (8AT)
was using map7 + MS109 racegas.. lifted off throttle and pressed it again it went magically like nothing happened.. plus there was no sound or anything since that day. that day i was doing logs for map7 ** did you hear anything or feel anything bad , did it go with time ?
Docrace 6266
02-26-2014, 11:03 AM | #4 | |
Rep 463
02-27-2014, 09:39 AM | #5 |
Rep 1,349
Drives: BMW F80 M3
What map are you running? Shifting manually or auto?
02-27-2014, 11:18 PM | #9 |
BimmerPost Supporting Vendor
24421
Rep 191,338
OP post some logs
Thats not 100% accurate
02-27-2014, 11:20 PM | #10 |
Rep 1,136
I'm seeing more people with tunes having limp modes. Its one of the reasons I want to wait until things get ironed out.
sent from bimmerpost Android app
02-27-2014, 11:22 PM | #11 | |
24421
Rep 191,338
Tunes do not cause more problems if you do logs and make sure your car reacting well to the map you have.That is why after we sell a tune we still provide support and encourage customer to do logs and send it to us
02-28-2014, 09:45 AM | #12 | |
Rep 1,997
This is, in fact, the only time I've seen one with the JB4, but have seen a ton without. It could very well be the car not the tune. The tune just brings in one more variable into the mixture. Sure it's possible it could be a faulty tune (just as we see OEM issues), but I don't think it's fair or logical as data would say otherwise that the JB4 is causing drive train malfunctions at a higher rate than stock or mppk cars. |
02-28-2014, 10:01 AM | #13 | ||
Rep 1,349
Drives: BMW F80 M3
02-28-2014, 10:02 AM | #14 | |||
Rep 463
02-28-2014, 12:48 PM | #15 |
Rep 1,349
Drives: BMW F80 M3
Thats your problem
I had the same on map 5. But map 5 is not supported on f series yet. If you let the gearbox shift it will downshift couple of gears. When you are in manual you are stressing the box too much in high gear low rpm. So just start your pulls at least from 3k rpm onwards. My bet is it wont happen again. |
02-28-2014, 12:49 PM | #16 | |
Rep 463
02-28-2014, 01:02 PM | #17 |
Rep 1,349
Drives: BMW F80 M3
Forgot to mention dont start pulls in 7th or 8th at all. 6th as of 3k is fine. Lower gears all is fine.
02-28-2014, 01:39 PM | #18 |
Rep 923
No issues with JB4 map 2 + ER DP + intake... I haven't floored it in higher gears from low RPMs but I mean you're bogging your engine by doing that so it may be normal that it's causing some issues.
It's like trying to drive off in a standard car in 5th gear, putting unnecessary stress on the drivetrain. Gears 7 and 8 are very tall gears and are solely there for fuel economy...
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
