BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) More X1/X2 Info
      03-24-2014, 10:43 AM   #1
SCOTT26
SCOTT26's Avatar
5311
Drives: A big F-off German Truck.
Lightbulb More X1/X2 Info
The second-generation BMW X1, expected here in early 2016, is smaller and lighter than the existing first-generation model.
The new X1 loses optional six-cylinder power; a new high-output four-cylinder replaces it. A high-ranking BMW manager confirmed the new X1 abandons today's longitudinal engine layout for a version of the new transverse-engine platform the 2-series Active Tourer uses.
“The next X1 will be slightly smaller externally but offer similar interior space as the first generation model,” he said. “The decision to base it on a new platform structure shared with the 2-series Active Tourer will also make it lighter than the model it replaces.”
At 176.2 inches long, 70.9 inches wide and 60.8 inches high, the first-generation X1 is 3.5 inches longer, 1.2 inches narrower and 1.8 inches lower than its main European rival, the Audi Q3. The second-generation X1's slight dimension reduction means BMW is widening the gap between the X1 and recently facelifted, second-gen X3, getting ready for a new X2 in 2017. X2 is the new X1, only sportier. X2 and X1 share a platform, transverse engines and interior.
The new X1 and X2 use transversely mounted three- and four-cylinder direct-injection gas and common-rail diesel engines ranging in capacity from 1.5- to 2.0-liters –same as the 2-series Active Tourer.
X1 and X2 will be all-wheel drive with either a standard six-speed manual or optional eight-speed automatic gearbox and electro-mechanical multiplate clutch four-wheel drive system. Unlike the new 2-series Active Tourer, the new X1 is not planned to be sold with front-wheel drive.
Since the two new Xs use transverse engines, there will be no traditional in-line six cylinders, although sources also say BMW is developing a powerful new direct-injection 2.0-liter turbo four producing around 300 hp, part of its new B48 engine family. The idea is to compete with the Audi Q3 RS' 296 hp and the Mercedes-Benz GLA45 AMG's 355 hp. BMW's new high-output four should find its way into planned X1 and X2 M-Performance variants.
Meanwhile, sources tell Autoweek the new X1 is set for at least three BMW assembly sites. Along with today's production facilities in Leipzig, Germany and Shenyang, China, it will also roll out from a new factory in Araquari, Brazil -- the same plant being tooled up for the 2-series Active Tourer.
The Brazilian plant, in the southern Brazilian state of Santa Catarina, will produce the new X1 for export to North America, among other unconfirmed countries.
The next 1er Sporthatch will also be built in Brazil as will the MINI countryman and the BMW 3er.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
      04-05-2014, 06:17 AM   #2
VAnative
Drives: 2014 BMW 435i, Mineral Gray Me
So this is what is extremely confusing to me. The 2016 X1 will be on the same chassis, have FWD and AWD, use at least some of the same engines and be built at the same location as the 2-Series Active Tourer. Frankly, they look pretty similar too. What exactly will be the major differences between these two vehicles?
Say all you want about the 2-Series AT, it does have a big market potential in the US. It's a good looking car, fills the need for more utility than a 3- or 4- series, and should be cheaper too. The only question is why would I want an X1 over a 2-Series Active Tourer?
2014 BMW 435i Sport Line
Mineral Gray Metallic
ZSL, ZDH, ZTP, ZLP, ZCW, ZPP, ZDB, ZDA, SDF
      04-29-2014, 08:29 PM   #3
Black Flagged
Black Flagged's Avatar
Drives: M2C
Thanks Scott, that answers a lot of my questions.
      05-16-2014, 07:56 AM   #4
Red Bread
Drives: Smog machines
So fwd BMW's will be Brasilianer Motoren Werks?
xbimmers
