04-07-2014, 03:03 PM | #1 |
1768
Rep 7,652
IND Painted Reflector Installation Procedure
Painted reflectors are among the first additions made by any owner of a modern BMW. The unsightly orange reflectors installed in cars bound for North America instantly break the smooth lines of BMW bumpers.
IND provides painted reflectors as a cost effective solution. We use OE BMW reflectors for a factory fit, and the same paint process we would use to repaint an entire car. Each reflector is sanded, prepped for paint, primed, then painted. Many enthusiasts enjoy installing their own painted reflectors, so we’ve created this installation DIY to help. Tools needed: • 8mm socket and ratchet Step 1: The first step is to gain access to the fender liner. This can be achieved by turning the wheel full lock toward the inside of the side you are working on. As a result of this action you have a clear view of the fender liner as well as the fasteners Step 2: Now that the fender liner is visible take the socket and remove 3-4 of the fasters so that you can safely access the reflector. Step 3: The F22 reflectors are not secured with double-sided tape, but rather snapped into place. There are two tabs on the backside of the reflector and the safest way to remove the factory piece is to depress the tab inward and simultaneously push the reflector. Once you have one end loosened you can repeat with the other tab. Step 4: Installation is as simple as push the reflectors into place. This is performed from the outside of the bumper Step 5: Now that your reflectors are installed it is time to button everything up. Simply replace the fasteners on the fender liner and repeat with the other side.
04-07-2014, 05:08 PM | #2 |
10820
Rep 27,601
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
05-07-2014, 09:57 PM | #5 |
Rep 1,115
06-24-2014, 12:51 PM | #9 |
Rep 462
I tried doing this myself yesterday. I can get to the top clip and may be able to get it to release with some force. But there is no way I can get to the bottom clip and to let it go. I'm afraid to pull on it and have it break the plastic that is actually holding the reflectors.
06-24-2014, 01:59 PM | #10 | |
Rep 8,942
Worst case I was going to epoxy mine in bc you can't see what's behind it but it worked fine.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-24-2014, 02:18 PM | #11 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Yea ones the top is off, you use the top as a handle and pull the bottom off
Dont just yack it out but slowly pull it out
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
06-24-2014, 02:31 PM | #12 |
Rep 8,942
Yeah that's a better way of saying it. Assuming you are on the passenger side, with the top out use left hand to pull the foremost tab on the bottom as far rearward as possible, then pull the top down with your right hand while rotating longitudinally towards the rear to wedge the depressed front tab out first. If that makes any sense at all. It's a little panic inducing but overall not that bad.
06-24-2014, 02:43 PM | #13 |
***** noob
1370
Rep 10,479
Oh and for the top, if you can get your hands behind the bumper...use a mini plier to release the clip
2006 325xi (Sold)
06-27-2014, 07:40 AM | #14 |
Rep 1,053
Has anyone who has the parking sensors done this? The parking sensor sits right next to the reflector where you are supposed to reach in from the wheel well. I ordered a set of the IND's but have yet to attempt.
06-27-2014, 08:58 PM | #16 |
Rep 1,053
Thanks. I just did mine as well and it was straight forward.
Thanks to IND for a great color matched part! (MG for me) Last edited by five3three; 06-27-2014 at 09:42 PM.. |
07-06-2014, 09:05 PM | #18 | |
Rep 8,942
2022 Macan S
07-06-2014, 10:01 PM | #19 |
Rep 5,262
07-08-2014, 08:54 AM | #20 |
Slightly Less Obsessed
26
Rep 317
This is probably a dumb question, but was there a law that mandated these reflectors be installed?
I was looking around yesterday at other cars and see more rear reflectors than front ones, but there doesn't seem to be any rhyme or reason as to which cars have front reflectors. |
07-08-2014, 09:33 AM | #21 | |
Rep 8,942
2022 Macan S
07-08-2014, 05:54 PM | #22 |
Rep 38
So, without knowing the laws, it would probably be safest to install clear or smoked reflectors in the front and back, assuming I can find them.
