THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Carbon Interior - My progress; Self made.
      04-12-2014, 12:03 PM   #1
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Hiyo.
I got a little bored as I am waiting for my OEM BMW Performance interior to arrive, I decided a few days ago I'd wrap my current OEM in carbon.
I wanted to just try one piece, as this is my first time wrapping interior trim in carbon. First off, I am by no means an expert. I have played around with resins and fiberglass before and I figured I would give this a shot. I simply attempted with one piece first (driver side door handle) and currently still in the process.
Started by taking the piece off and cleaned with dish soap.
Sanded down with 120 Grit - 240 Grit
Measured out the carbon. Gave my self an extra ~1" in each end.
Getting ready to coat with black base coat
Base coat applied, using a heat gun to get out all of the little bubbles
At this point, I never took a picture of the carbon being raw. I had to relay the carbon due to me not letting the base coat sit long enough.
This was after two coats of top resin and then sanding down the edges to make them flush with the piece.
Test fitting, no clear coat and no sanding yet. This was simply to ensure everything fit without a problem.
I've now just sanded down from 140 - 1600 grit. Wet sanding took place at 400 grit and up. I broke threw at one spot so I had to go and reapply resin and now I wait for it to dry. Once it's dry, I'll re sand that area and apply the clear...
Stay posted.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com
Current: 2015 Cayman S on HRE P101
      04-12-2014, 12:41 PM   #2
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
I call you BS that its your first time ahahah
Thats impressive work
You'll need some pro-grade clearcoat or its going to yellow over time
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      04-12-2014, 01:01 PM   #3
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
How did you remove the handle from the door? I read you pry from the bottom of the handle and work your way up to the top. Any plastic clips I need to be careful about in getting them to release?
      04-12-2014, 01:05 PM   #4
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Yup, first time. I've picked up a UV resistant clear from my local auotbody shop supplier.
Started from the bottom with a trim pulling tool. Took a little force but work your way up slowly. I damaged one clip on the driver door but I put it back in and things are fine.
      04-12-2014, 01:26 PM   #5
PabloK
PabloK's Avatar
Drives: F30
Very nice!
Want to make me a set?
      04-12-2014, 01:54 PM   #6
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Originally Posted by PabloK View Post
Very nice!
I can, you would just have to be responsible for shipping. I can pick the set up in North Dakota. Will take one week turn around.
      04-12-2014, 04:56 PM   #7
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
OP this is really cool! Great job.
I may have to consider in the future, since I like the glossy CF interior a la new M3/M4, and the current one is more alcantera
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      04-12-2014, 05:54 PM   #8
Brooklyn Mark
Drives: 2013 M3 MR E92 DCT
great work op!
      04-12-2014, 06:18 PM   #9
Cripple
Cripple's Avatar
102
Drives: 12' 335is
I wasn't happy with how the first handle came out so I went for a go against my drivers door handle today while waiting for the resin to dry on the passenger one. Here is the step I took to ensure all the end are bonded to the surface of the original handle.
      04-12-2014, 06:40 PM   #10
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
That looks like it will turn out great, especially for a first time!
Slightly off topic as I realize it's a totally different process and not real CF, but figured those doing CF might have researched alternatives. Saw an old Wheeler Dealers w a Range Rover where they painted the trim black then floated a CF textured film in some sort of solvent and dipped the parts. Before I do a ton of research, anyone know the name of the process and/or if the results are any good? Looked great in TV but then again anything can look good on TV and look terrible in person.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      04-12-2014, 07:16 PM   #11
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Wasn't entirely happy with this one either. We will see how this dries
      04-13-2014, 12:21 PM   #12
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Well today I sanded down that first coat of resin.
Applied second coat and now we look like this.
      04-13-2014, 12:22 PM   #13
300f87
300f87's Avatar
51
Drives: 2018 M2
Nice work, cripple!
That would be hydrographics or hydro dipping:
http://www.hydrographicsinc.com
      04-13-2014, 01:20 PM   #14
mkPOTO
Mr. Nice Says Hello
mkPOTO's Avatar
636
Drives: BMW M3 | X5 xdrive 35i MSport
wow stunning!
      04-13-2014, 01:30 PM   #15
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Thanks guys... I hope I can wrap the centre one too my liking this week
      04-14-2014, 06:33 PM   #16
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Well I was going to clear these today but I went to final sand on both and I had a spot of carbon break threw. I knew I was really light on the top coats so I decided to put one more coat on both before getting ready to spray. Figured I would let you see them before I spray. This is only half the gloss the clear will have.
      05-02-2014, 12:24 AM   #17
M_BYEEE
M_BYEEE's Avatar
Drives: BSM X5M
Wow looks awesome in my opinion. Keep up the great work
2addicts
