E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > High pitch noise and rough idle
Reply
      04-12-2014, 12:22 PM   #1
justanotherdude
justanotherdude's Avatar
Drives: 2010 AW 328 [Sold]
2010 BMW 328i  [0.00]
Car: 2010 328I E90
Problem: Drove to work no problems. Turned the car off, it sat about five minutes, turned the car back on and I got this high pitch noise coming from the engine compartment. Then the service engine light came on, and then the idle got real bad to where the whole car shakes and it sounds like it wants to cut out.
Video:
https://www.facebook.com/photo.php?v...24466136537706
Any ideas?
      04-14-2014, 10:15 AM   #2
yupetc
Drives: 2015 X535i
Definitely the pitch of a good vacuum leak.
Source of leak is beyond the MAF sensor. It's rough because air volume estimations are wrong and your car is running too lean given the fuel points with the extra air from the leak.
Best place to look:
Start from MAF sensor, check hose to throttle body, make sure clamp is tight. Follow into the intake itself, there are a few vacuum hoses around behind the intake for oil collectors and connections to valve cover breathing holes, check those. Also look around valve cover (will need to remove the plastic engine cover).
Report back your findings.
      04-14-2014, 01:55 PM   #3
justanotherdude
I don't have time to do it myself, took it into the shop.
Waiting on word while I take care of other shiz.
      08-02-2014, 07:32 AM   #4
yupetc
Drives: 2015 X535i
Did the shop ever tell you what the problem was? This is interesting to know. Suprised there isn't any follow-up.
      08-02-2014, 07:46 PM   #5
justanotherdude
It was the VANOS system. It had a loose bolt and was causing it to unseal and misfire really bad. A bad ignition coil followed, but once both were fixed everything was good to go.
      08-04-2014, 04:26 PM   #6
yupetc
Drives: 2015 X535i
Sounds good, thanks. I'll add that to my quiver of knowledge for troubleshooting car problems.
      08-06-2014, 07:19 PM   #7
Three_thirty_I
Three_thirty_I's Avatar
South Africa
200
Drives: '05 E90 330i Manual
A loose bolt where though? One of the bolts holding one of the Vanos solenoids in position, or something else? Have seen vids of very similar issue and identical noise which was due to a problem with the oil filter - often gets twisted from improper installation or otherwise gets deformed and restricts oil flow to the Vanos.
BMW E90 330i (M) '05 (His) | (Hers) BMW E46 320i f/l (M) '03
      08-08-2014, 01:25 PM   #8
justanotherdude
They told me it was one of the bolts that held the Vanos in place. Really all I know. :/
      08-08-2014, 01:39 PM   #9
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
I was under the impression that that was a N54/N55 issue only...
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      08-08-2014, 02:00 PM   #10
justanotherdude
Apparently there was a mass recall on the N52 Vanos unit that BMW supposedly never went public with or something.
      08-08-2014, 03:16 PM   #11
TheSt|G
TheSt|G's Avatar
How can you have a mass recall that isn't public? A recall be nature is a public thing.
      08-08-2014, 04:28 PM   #12
justanotherdude
That's what I said.
      08-08-2014, 04:37 PM   #13
TheSt|G
TheSt|G's Avatar
That's what I said.
Yeah this is odd. I'm having my friend who works for BMW look into it.
      08-08-2014, 07:25 PM   #14
Three_thirty_I
South Africa
200
Very keen to hear what he says about this! First I have heard of this.
      02-22-2015, 09:46 AM   #15
justanotherdude
I completely forgot about this thread.
Essentially what it came down to was a bolt from my VANOS system broke and caused the whole thing to kind of come loose. So it was creating a squeal from air being let into a place that it wasn't supposed to be going in through.
As far as the recall, I never heard anything back from the dealership, but it was free to fix so I'm assuming they found the recall.
      01-08-2016, 03:28 AM   #16
Petermoeller
Drives: BMW 325i N53 LCI
Hi, I am also hearing a loud pitch noise from the engine. It is a 325i Lci with a n53 engine. I am told that it's the injectors but the noise goes away sometimes and started at about 90.000km.
Could you post the video again so I can hear the noise? Maybe a link to a YouTube
Thanks
      01-08-2016, 09:28 AM   #17
Petermoeller
Loud noise and high fuel consumption N53 (2010)
Hello,
I have a 325i with the N53 engine (LCI from 2010) and two things happen:
1. There is a loud ticking noise from the engine (like a pinging noise) and it comes and goes away randomly. See this video
2. The fuel consumption is suddenly much higher than usual. Normally with mixed city/highway about 8liter/100km but now 10 liter/100km. See this video how the fuel economy gauge acts weird - with very gentle acceleration the consumption gauge goes all the way to 20liter....
Any ideas guys? It would be great to have your comments.
I have had new injectors installed (all 6), new coils (all 6) and 6 new spark plugs only 6 months ago. I have just replaced the NOx sensor, but this did not improve anything.
Now all my spark plugs are totally black....like the picture attached.
There are no related fault codes.
      01-08-2016, 09:45 AM   #18
justanotherdude
I no longer own this vehicle fellas. They replaced my VANOS system and my issue went away. I don't know what the others issues could be.
      10-26-2016, 03:35 AM   #19
neophyted
Drives: 08 330i
Originally Posted by Petermoeller View Post
Hello,
I have replaced parts exactly like you along with valve cover gasket, solenoid and have pretty much the same issue with my spark plugs and random high pitching noise apart from that I do not encounter the fuel consumption issue (yet). Replacing spark plugs cures it however there must be something else killing those spark plugs. I have been to many BMW specialists however no one could get to the bottom of it. Have you by any chance came across anything to solve it?
      10-26-2016, 09:03 AM   #20
Phil325i
Phil325i's Avatar
United Kingdom
624
Drives: E92 325i MSport Coupe
Your plugs should not be that colour. The N53 runs very lean and should not be giving you plugs that colour. I'd say you have a fueling issue. Try to find an indy who has access to the latest BMW diagnostic software that can scan your engine while it's running...
I'm assuming your air filter isn't filthy? Might be worth cleaning your MAF sensor.
And your engine sounds normal to my ears. N53s are very noisy (almost diesel-like) due to the piezo injectors.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      10-27-2016, 11:33 PM   #21
bmw201113
Drives: Bmw 328i coupe
The same exact thing happened to my car my vanos bolts completely sheared off and a spark plug somehow got pulled into a piston ended up needing a motor replaced
      11-25-2021, 05:20 AM   #22
nerrazur
Drives: F10 528i N53
Thanks
Hello,
Did you find out what was the reason for this noise?
Reply
e90post
