THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Rear deflector delete?
      04-18-2014, 10:10 AM   #1
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Anyone know if these exist or are in the works?
I worked up some paint magic. I think it looks good. The red is half and half to give perspective.
      04-18-2014, 10:15 AM   #2
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
You mean reflector I assume and not diffuser? Check with Andrew at IND I'm sure it's already in the works (see commercial classifieds exterior for contact info). Curious to see how install would go, having to pull the diffuser would be a bitch.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      04-18-2014, 10:21 AM   #3
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
lol yes, reflector...my brain does what it wants, sometimes.
I was wondering about installation too. If it is integrated too well, it would suck. I just think the look is good and more seamless than the orange reflector mods, which I can't get myself to do. Something about it from up close and seeing the lines bothers me.
      04-18-2014, 10:26 AM   #4
2blu
2blu's Avatar
Drives: 540i XDrive ///M Sport
You can plasti dip them. That's what I did on my F30.
      04-18-2014, 10:28 AM   #5
BEM-S4
BEM-S4's Avatar
Assuming you can get a decent color match that's 100% the easiest option. If it sucks you're out $5 and a little time.
2022 Macan S
      04-18-2014, 10:30 AM   #6
BEM-S4
BEM-S4's Avatar
I really don't think the lines will bother you after 5 mins unless it becomes some weird OCD thing. The headlamp washers etc already have lines around them. In any case it's a million times better than the orange.
2022 Macan S
      04-18-2014, 10:33 AM   #7
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
+1 for plastidip on these parts
You want to flow with the diffuser by going black color
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      04-18-2014, 10:54 AM   #8
SuitedUp
Drives: 228i MSport
I don't really mind the rear ones.
      04-18-2014, 11:08 AM   #9
2blu
2blu's Avatar
http://www.f30post.com/forums/showthread.php?t=908920
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
      04-18-2014, 11:19 AM   #10
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
I agree. I think it looks better than trying to hide them.
      04-18-2014, 12:10 PM   #11
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
That looks good. I am a bit OCD and will probably want to try to color match the diffuser color. Plastidip with a paint match could work, so that I could reverse it later. Just peel off the painted plastidip. Thanks for the ideas.
      04-18-2014, 12:19 PM   #12
2blu
2blu's Avatar
I have a Matt diffuser on my car now so the plastidip blends in quite well. You can always plasti dip first, then get a can of dark shadow paint and spray over it. And since you have plastidip under you could still peal it off to reverse it back to red or peel it off and try again.
      04-18-2014, 12:21 PM   #13
BEM-S4
BEM-S4's Avatar
No sense in not trying the plastidip first. If the match isn't perfect you can always paint later on but matching the diffuser color could be tricky there as well. Even stock at least they match the tail lamps so not horrible. You could also plastidip the entire diffuser as well to get the whole thing perfectly matched. That's probably the simplest way to go
The front is also infinitely better / easier to fix now that the reflector is on the bumper and not buried in the headlamp assembly.
2022 Macan S
      09-03-2014, 10:20 PM   #14
Geektechlive
Geektechlive's Avatar
Drives: 2022 M3 Competition
Just came across this great thread. Can someone confirm or deny that the rear reflectors are part of the diffuser? I am asking since I will probably get a different diffuser when upgrade my exhaust and well I don't want to buy the IND deletes and then not need them.
Thanks in advance!
Owner of a 2022 M3 Competition AWD in Individual Voodoo Blue and Fiona Red leather
      09-04-2014, 11:37 AM   #15
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
Thanks in advance!
They are independent of the diffuser.
      09-04-2014, 01:08 PM   #16
Geektechlive
So if I get a CF diffuser from IND it would make more sense to get a color matched rear delete in the body color (Black Sapphire Mettalic)
Just confirming my suspicion. anyone else do this?
      09-04-2014, 02:04 PM   #17
hyperzulu
hyperzulu's Avatar
Drives: 2015 M235i
http://www.2addicts.com/forums/showthread.php?t=1011035
2addicts
