04-18-2014, 09:33 PM | #1 |
Rep 524
LED DRL coding?
Hi, bought and installed LED bulbs for the DRL.
I was updating my NAV today and turned off the DRL in iDrive and noticed that due to error checking, it would blink on and off every few minutes. Is there coding to change the regular bulb DRL to LED DRL or to delay the error checking such as for the LED FOG and corner lamps? |
04-19-2014, 11:07 AM | #3 |
Rep 524
06-29-2014, 03:34 PM | #4 | |
Rep 1,480
Drives: 2020 M340Xi (G20)
Understand that you can code DRL for LED; there are three items in FEM_BODY to code:
What is the "prefix" (the first three XXX) for DRLs when you replace with LEDs -- I can not figure that out? Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
06-29-2014, 05:29 PM | #5 | |
Rep 524
TFL_L and TFL_R for the 3 setting above. |
06-29-2014, 05:51 PM | #6 | |
Rep 1,480
So TFL will work for these -- as the name implies? Again, thanks!
Al
06-29-2014, 06:14 PM | #7 |
Rep 524
06-29-2014, 06:23 PM | #8 |
Rep 1,480
Great -- that even what the name means! Someone told me that it was POL (the parking lights), but in our case I think that is for the little H6W bulb tucked in the upper corner of the high beam slot.
Again, thanks!
Al
