headlight washer cover
05-20-2014, 12:44 PM | #1 |
Rep 33
Had a little incident with the car and the headlight washer cover has come off, i still have the cover and it has two springs attached to it, its just im a little unsure how to get it back on.
Any help? |
05-20-2014, 01:04 PM | #2 |
Rep 1,184
yup i had this problem!
basically, pull the springs off the plastic piece which goes on the actual washer jet... then you twist the big end of the spring into the holes in the washer cover... use your finger nail to separate the last coil of the spring and twist it in.... then after just clip the springs back into the plastic piece and then clip that onto the washer jet.... (i found it helped to use pliers to stop the washer going back in while i clipped the cover into place).... hope i helped!
PAST: 2007 E93 335i 6MT NOW: 2012 F10 M5 Facebook: Achu Ckr|Twitter: AchuCkr|Instagram: AchuCKR|Flickr: AchuCKR|G+: achu.ckr THE BUILD THREAD|COMPILATION OF PHOTOS |
05-20-2014, 01:06 PM | #3 |
Rep 1,184
oh wait, just read the washer cover still has the springs on it? in that case just pull out the washer jet with you hand and pull off the clip... then just clip it onto the springs
