05-28-2014, 06:08 PM | #1 |
Rep 1,040
Carbon/Alcantara Interior Trim Installed
New trim kit arrived from Sun Motors this evening. Took me 25 minutes to install including gathering up the tools. Really goes well with the steering wheel.
05-28-2014, 06:16 PM | #3 |
Rep 8,942
Looks great, much better with the wheel as well. Just curious, do they make a shifter surround? That's all that left of your aluminum trim right?
05-28-2014, 06:28 PM | #4 |
***** noob
1370
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Get this...contact Sun ($120 shipped)
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
05-28-2014, 07:26 PM | #5 |
Rep 8,942
05-28-2014, 07:41 PM | #6 |
Rep 1,040
05-28-2014, 07:52 PM | #7 |
Rep 8,942
I can ask my service manager friend to check if you like. I think the e-brake takes some muscle but is doable, same for a standard knob but the auto version looks like it would be a bitch and possibly delicate w all the electronics. I assume if you break the stuff that stays and is reused with the new knob it could be a nightmare. Sun provided the instructions straight from BMW for my pedals, you could ask them too.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
05-28-2014, 11:25 PM | #8 |
Rep 148
Looks good OP. Two Qs.
1. Anyone know if it's possible to order the alcantara piece above the glove box by itself? 2. BEM S-4, how difficult was the pedal install? Hearing about the need for drilling put me off. |
05-29-2014, 06:42 AM | #9 | |
Rep 8,942
One thing they don't tell you, the back side of the brake pedal (the metal base that you drill into) is not flat, there's a lip and the lever or whatever it's called that it's attached to. When you tighten the bolts it's hard to get them super tight because the locking nuts will get tight to a point then you just spin them around. You can but it's difficult grip them with some needle nose pliers from behind. If you use a socket to hold the nut and then tighten with a screwdriver it's MUCH easier. One other thing after drilling there is a fair bit of sharp blowout stuff back there, clean it up with a low grit sanding pad. Do not rub your finger back there to see how bad it is like I did, you will then be cleaning blood off your new pedals. The gas pedal is super easy you are drilling and screwing into plastic. One thing I would advise is that the directions call for 2.8mm bit, I got 3.0mm because it's all I could find. Go smaller 2.0mm if it's all you can get your hands on, you are just drilling into plastic and the screws will be a bit tighter. One of mine is a tiny bit loose but it doesn't matter the whole thing is held on with adhesive think the screws are superfluous at best. |
05-29-2014, 11:35 AM | #10 | |
Rep 1,040
I did the M Performance pedals myself and it was as described. Use the supplied rubber backing as a template to make your pilot holes. Remove and drill out with the required size drill bit. I used a dremel grinder on the back of the pedal to smooth out the shavings (20 seconds per hole). I did small pilot holes for the gas pedal cover and they supplied screws are self-taping a bit and hold tight to the accelerator pedal. Note, the entire backing of the accelerator cover is double-sided tape to help keep it in place. |
05-29-2014, 11:37 AM | #11 | |
Rep 1,040
** Found a picture of the shift knob parts, just covers and new button ** Last edited by Delnari; 05-29-2014 at 12:59 PM.. |
05-29-2014, 01:38 PM | #13 |
***** noob
1370
Rep 10,479
Yes same clips as the trims
2006 325xi (Sold)
06-06-2014, 07:07 AM | #14 |
Rep 1,040
Took the good advice and installed the remaining two pieces; shfit knob trim and shifter surround trim. Ignore the white specs that still floating around from when I had the car dyno'd. Might take me several vacuums to get them all.
06-06-2014, 07:25 AM | #15 |
Rep 1,040
The issue with doing the shift knob cover is there is a T-8 Torx screw in the center under the shft pattern cover. It is a tight aluminum screw that taps into a plastic sleeve that is very tight. To do the job right you will need the correct size bit.
06-06-2014, 08:38 PM | #16 |
Rep 1,040
Passenger side trim cover has popped off at the top and won't stay seated any longer. Tried removing and re-installing with the same effect. Contacted Sun Motor Cars BMW for a replacement to see if that will fix it. Will update after part arrives.
06-06-2014, 08:43 PM | #17 | |
***** noob
1370
Rep 10,479
2006 325xi (Sold)
06-07-2014, 09:53 PM | #18 |
Rep 1,040
Yep, the "L" shaped hook is at the bottom and is in place. I have re-installed this cover a second-time (removed it completely) with the same results. It snaps down on top then immediately pops back out. My guess is the piece has a slight bend that doesn't allow it to stay down, or the plastic molded clip on the top of the piece is not exactly formed right. Either way, I have a new piece coming to try soon.
The driver side is perfect with no gaps; hopefully this is just a bad piece on the passenger side. |
06-11-2014, 07:03 PM | #19 |
Rep 1,040
New piece shipped on Tuesday and arrived today (Wednesday). Pulled original cover off and popped new piece on. Fits factory tight like it should. All's good in the world again, including my M235i interior.
Thumbs up for Sun Car Motors BMW and Brian |
08-03-2014, 09:46 AM | #21 |
Rep 60
Interior looks great! My shifter and surround are arriving tomorrow was it the case that you remove the surround first to reveal a way to take off the shifter?
