05-29-2014, 03:52 PM | #1 |
384
Rep 548
Hey guys... Picked up my 2014 Msport package 228i on Saturday from Mckenna BMW. Being that I work in the parts department, I went a little crazy and bought everything for the car right away.
I ordered what was readily available which is the the M performance gloss black grills, M235i rear diffuser and a set of H&R lowering springs from my buddy Zeek over at EAS (European auto source). Suspension will be going on tomorrow, diffuser and custom muffler delete exhaust will be going on Saturday. If time permits, I'll be getting some wheels test fitted as well (18x8.5 et30 and 18x10 et35). Can't wait to start posting install pics. |
05-29-2014, 06:12 PM | #3 |
Rep 1,040
Do me a favor. Take some pictures of the gear shift knob install. I just ordered the kit and want to be sure I can get the original cover off without too much trouble. Really appreciate!
05-29-2014, 11:38 PM | #6 | |
384
Rep 548
05-30-2014, 07:22 AM | #10 |
384
Rep 548
05-30-2014, 12:46 PM | #13 |
Rep 775
The springs will be different based on the front weight of the car being different. I believe however they will bolt in, just won't be the correct spring rates.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
05-30-2014, 12:50 PM | #14 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
subscribed! Congrats on the car and the mods!
05-30-2014, 12:58 PM | #15 |
Rep 269
I would think that too, except the same H&R part number (at least for sport springs) is used for F-series 320i, 328i, 335i, 428i, and 435i. Those cars have extremely similar weight differences between them as 228i vs M235i. Obviously things will be different, but I wonder exactly how "wrong" the spring rate has to be to be unacceptable. Once you're spreading that weight difference out over four corners, I imagine the difference becomes less important.
05-30-2014, 01:24 PM | #16 |
384
Rep 548
We'll see how it drives after the springs. I already had the M sport suspension to begin with and I was sitting at 25 3/4" on the front and 26 1/4" on the rear. Don't think I've read any final measurements yet of how low they're going to go.
06-03-2014, 03:50 PM | #18 |
Rep 2,364
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Where did you get the tips from? Are you putting them on the stock exhaust?
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
06-04-2014, 02:41 PM | #20 | |
384
Rep 548
http://www.2addicts.com/forums/showthread.php?t=992564 |
06-04-2014, 05:34 PM | #21 |
Rep 1,040
You almost got me on this one. The shift cover is held on by a screw and does not snap off/on. A new screw comes with the cover Appears the head of the screw is a T-8 or smaller torx which I didn't have so I used a small flat blade screwdriver instead. Painful but manage to get old one off and new one on. If you get the replacement cover make sure you have small torx drivers, below T-10 or you will struggle to get this installed.
