THE LARGEST BMW 2-SERIES FORUM ON THE PLANET
2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications Mirror cap replacement
      06-13-2014, 12:29 PM   #1
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Can someone post the instructions for replacing the mirror caps on an M235i?
I just bought the M Performance caps from Sun Motors. Great price by the way. At their price I decided not to try the after market ones.
      06-13-2014, 12:46 PM   #2
lichenlt
Drives: M235i
I believe you can just pop them right out with your hands firmly press against them.
The OEM ones are in $500-600 range, right? The aftermarket ones are like $100-150. Maybe I'm too cheap but I'd rather spend the money elsewhere since I can't tell the difference from two feet away when they are on the car.
      06-13-2014, 04:59 PM   #3
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Grab the corner on top, closest to the car and pull hard. It will pop right off. I found it hard to get a good grip on the top edge.
      06-20-2014, 07:07 PM   #4
DanG
DanG's Avatar
2018 BMW M2  [7.68]
The M Performance mirror caps are a bear to put on. They are held in place by three screws. They require disassembly of the mirrors.
I gave up and had the dealer install them.
One added note: they do look great once installed.
      06-23-2014, 12:02 PM   #5
BEM-S4
BEM-S4's Avatar
I went with color matched from IND as another alternative. Those just pop on and look a million times better than the stock ones.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      06-23-2014, 12:42 PM   #6
TaiChiSteve
TaiChiSteve's Avatar
Drives: 2015 M235i EB/Terra
Do you have a link for these?
I'm interested in replacing the stock ones with ones of the same color as the car.
      06-23-2014, 12:50 PM   #7
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Here you go: http://ind-distribution.com/ind/m235...d-mirror-cover
      06-23-2014, 01:24 PM   #8
TaiChiSteve
Originally Posted by DanG View Post
Thanks Dan, already saw those and will be getting those along with the all blk grill. Do you know of any aftermarket mirror caps that are the same color as the car itself?
      06-23-2014, 01:46 PM   #9
bman6074
Drives: 14 M235i and 07 Lotus Exige S
I believe it is very similar to these DIY's on E90
http://www.e90post.com/forums/showthread.php?t=74675
      06-23-2014, 02:22 PM   #10
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Sorry, fixed the link to the caps.
Here it is also: http://ind-distribution.com/ind/m235...d-mirror-cover
      06-23-2014, 02:52 PM   #11
TaiChiSteve
Perfect.
Thanks DanG
      06-23-2014, 04:28 PM   #12
BEM-S4
BEM-S4's Avatar
Perfect.
Thanks DanG
Mine are mineral grey the color match is spot on perfect. Also was able to sell the originals so they cost me next to nothing.
2022 Macan S
      06-23-2014, 04:47 PM   #13
TaiChiSteve
Do they just snap on or are screws needed as with the M ones?
      06-23-2014, 05:31 PM   #14
DanG
DanG's Avatar
2018 BMW M2  [7.68]
They are factory caps that are painted. They snap on. No tools needed.
      06-23-2014, 06:11 PM   #15
BEM-S4
BEM-S4's Avatar
Just be careful to line them up and push them straight on. They don't clip in then rotate down to lock or anything like that. The first one I kind of fucked up but was lucky and got it off without breaking anything and did it properly the second time.
2022 Macan S
      06-24-2014, 09:33 AM   #16
ManCityFan
Drives: Evo IX MR
+1. it is very difficult to get your fingers under the edge b/c the gap is small. i had to use a plastic tool to pry up one of the corners and then work my way around until they popped off. once you have the stock caps removed, the CF knockoffs snap on very easily.
      06-29-2014, 07:24 AM   #17
Steven1077
England
240
Drives: M140i
Why don't they give the option of colour coded mirrors on the M235i? I really don't like the silver ones that come as standard, they would be better off just painting them the same as the car and giving a carbon option from the factory
      06-29-2014, 07:26 AM   #18
bman6074
+1 i had mine painted body color along with the diffuser
      06-29-2014, 10:46 AM   #19
CONTROL ONE
CONTROL ONE's Avatar
70
Drives: 2014 BMW M235i
You literally just pull them off as everyone has mentioned.
The CF mirror caps are the only non-BMW part I bought as for $150 vs $500 for nearly identical looks, it was an easy choice. These are the full 1:1 replacement housings.
Looks great with the 18% ceramic tint. Really makes the grey mirrors seem like such an odd choice by BMW.
      06-29-2014, 11:23 AM   #20
oscr972
Drives: M235i 4/16/14 ED AW/Terra
Bman6074, I'm thinking of getting my diffuser painted as well. I haven't checked pricing yet. What is a reasonable cost? Thanks.
      06-29-2014, 03:39 PM   #21
bman6074
I would think around 200 if you take it off yourself maybe 250 if they do it. It was part of my deal when I bought the car from the dealer. So I don't know the actual cost.
2addicts
