BMW M2 Forums 2023+ (G87) Engine, Exhaust, Drivetrain, Tuning Modifications
      03-22-2024, 12:34 PM   #23
M_Power Rob
Drives: '23 M240 and '23 M2
Originally Posted by DrewNewM2 View Post
Is it just the clutch that’s the weak point with the manual or the entire transmission? A clutch is a a pretty easy upgrade. Also need to figure out how to get some traction with 600-700 whp and RWD.
If you are just keeping in the 600-700 neighborhood, then I believe the clutch is your weak link.
On the ATM, if going between 750 - 1000, I would personally upgrade to a stage 1 transmission.
To get the car to hook up, meat (wider tires) and running drag radials in the rear are a must. I am basing on a drag race type of setup.
      04-02-2024, 06:50 PM   #24
DNTRYM2
Drives: 2013 M5
I thought this thread was asking if its possible to get 600 - 700whp without ECU unlocked and just piggy backing.
I also have this question, what is the best piggyback setup to get between 6-700whp range? Will DP, exhuast and piggyback make this possible? Seems like all the piggybacks are extremely conservative. Any recs?
      04-03-2024, 11:49 AM   #25
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Anytime you are going over a simple tuner for a stock car, the JB4 is the answer.
700 whp with DP and exhaust are not possible. you will be closer to 600whp with that kind of setup.
https://x-ph.com/sale/
Phone number 702-494-9435
