06-23-2014, 11:26 AM | #1 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
FS: DINAN STAGE I Suspension(NON-EDC)
DINAN STAGE I Suspension(NON-EDC): $650 including shipping CONDITION: USED, only 3k miles more info from DINAN's wesite: "Dinan's Stage 1 Suspension System provides greater control over body roll by virtue of carefully calibrated spring rates designed to work in conjunction with the original-equipment standard or EDC shocks and struts. Dinan® lowers the M3 by 1/2" front and rear for improved suspension geometry and an even more aggressive stance. Matching bump stops and replacement front guide supports are included that actually increase suspension travel by 10mm for improved handling capabilities along with surprisingly civilized ride quality. The higher spring rates, increased suspension travel and improved suspension geometry give the M3 even more grip for faster and more predictable cornering capabilities. All of the factory strut/shock system are maintained for cars equipped with this option." Benefits: + Reduce Body Roll + Retain Factory strut/shock functionality + Lower Ride Height by 1/2" in Front & Rear + Improved Suspension Geometry + Increase Suspension Travel By 10MM + Superb Ride Quality + Improved Mechanical Grip In All Conditions
06-28-2014, 02:15 PM | #3 | |
Rep 5,069
All other PM's replied.....
07-19-2014, 11:40 PM | #4 |
Rep 5,069
Bump, still available!!!
07-21-2014, 05:41 PM | #5 |
Rep 5,069
All PM's replied and on a side note I still have an almost new set of TMPS.
Thanks! FS Thread: http://www.m3post.com/forums/showthread.php?t=1001777
07-27-2014, 01:32 PM | #8 | |
Rep 5,069
08-02-2014, 05:59 PM | #10 |
Retired Curmudgeon
2989
Rep 4,057
OP: Since you've had this on an E90 and an E92, what's the difference between the two sets. Dinan has separate part numbers and the E90 one costs $100 more. Just curious what changes between the sets...
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
