07-06-2014, 09:54 AM | #1 |
Rep 1,042
4 series m performance bbk fit our cars?
May be a dumb question but would these fit our cars? Specs seem almost the same and would benefit from a real 4 pot bbk for $1900.
http://www.getbmwparts.com/partlocat...catalogid=4462 Fronts are 10mm larger. 370x30 vs 360x30 Thoughts?
07-06-2014, 09:57 AM | #2 |
Rep 542
My thoughts, exactly--especially the carbon setup.
* '11 E71 X6 M MCB
* '16 Z51 M7 C7 Corvette--SCCA Solo/DE Weapon * '90 Corvette ZR-1 (Fast) |
07-06-2014, 01:27 PM | #8 | |
Rep 4,488
I believe OEM and aftermarket rear calipers on our cars also need to be tweaked to accommodate the parking brake, in which case front calipers on the rear won't work.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
11-08-2014, 03:39 PM | #10 |
just another M3
514
Rep 1,152
I believe it does. the carbon setup uses same caliper as f10 m5
this put it on 1m. http://www.1addicts.com/forums/showthread.php?t=1053632 read the description for brakes. More research needs to be done
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
11-08-2014, 04:44 PM | #11 |
Mr. Nice Says Hello
637
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
Nick they will work with a bracket. I have someone who will be doing the swap on a E39 M5.
