07-14-2014, 11:56 PM | #1 |
Rep 4,848
Yokohama AD08R Pressure?
Has anyone got experience with the tyre? I am going to be running them this weekend as the track is going to be around freezing weather. What pressure do they usually run at?
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
07-15-2014, 12:05 AM | #2 |
Thread killer
646
Rep 1,896
Apples vs oranges?
I run my AD08s around 35 psi hot.
I found this, also: http://www.yokohama.com.au/News-and-...ace-tyres.aspx |
07-15-2014, 12:32 AM | #4 | |
Rep 4,848
Anyway, thanks for the tip .
07-15-2014, 12:39 AM | #5 | |
Rep 4,848
07-15-2014, 12:41 AM | #6 |
Rep 16
Didn't mean anything in that way. Apologies if it upset you. 31-32 and u good to go. Should peak around 37-38
07-15-2014, 03:58 AM | #7 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
07-21-2014, 07:06 AM | #9 |
Rep 4,848
Thanks for your help. Seems to run great on 38 hot at Morgan Park - temp quite consistent, except for left rear which runs a lot hotter than the rest on the sides. I had a fantastic day with Paul - great tips on my driving.
05-14-2015, 11:17 AM | #10 |
Homyseed
69
Rep 261
My pressure for Nordschleife:
front 29psi (hot) rear 28 psi (hot) Road pressure are 33.5 psi all around.
NOW: '11 BMW 1M AW "Nabila"
PREVIOUS: '09 BMW 335i DKG (DCT) "never too big" BEFORE:'09 BMW 135i F1 Sauber Edition 120/135 Team Homyseed |
05-14-2015, 01:53 PM | #11 |
Rep 2,898
06-20-2015, 02:00 PM | #12 |
Homyseed
69
Rep 261
Been using on track yesterday again, 2.0 bars hot front / rear. (28 psi)
06-21-2015, 12:45 AM | #13 | |
Rep 2,819
Drives: e82 1M, f87 M2cs
I have another track day coming up and plan to try 37psi front/36psi rear, which is about 1-2 psi lower than my last day, treadwear seemed OK. I am using RE11's, completely stock setup otherwise. |
06-22-2015, 03:01 AM | #14 |
Homyseed
69
Rep 261
As spoken with local Yokohama importer, the AD08-R is made to ride as a semi slick, even if it's not (it's not caged).
2.1/2.2 hot is the right pressure for track, as I'm riding 1.8° camber on four wheels. The tires look is great and regular all around.
06-26-2015, 03:28 AM | #15 |
Rep 2,819
Started new thread since the tires are different, but my "seat of pants" 39 front and 38 rear for my tires was pretty close to spot on . . . different tires, but still think 28 psi hot is very low at the track, probably good for autocross.
