09-05-2014, 11:17 AM | #1 |
Rep 3
What type of battery? lead acid or AGM, how to replace
Thanks to all who post here, I've learned how to change oil to changing front brakes. At first I was hesitant to even touch my wife's 2009 BMW 128i but after reading this I felt better.
Now, I've been reading about AGM batteries and I thought those were in all BMW but when I contacted the dealer he thinks my car has an lead acid bat. He also said a battery replacement will be $425-475 and another $125 to register. He actually stuttered trying to explain. I can buy one from Auto Zone for $150-175 lead acid or AGM and I've read to attach either a charger or another jumper car to the terminals under the hood. Then remove the battery, but the battery has a big red thing over the positive terminal, how is that removed. I think I've read that there is a switch in the red block? Also there is a little BMW shop a few miles from the house who will register it for $50 Sorry for the long post. Thanks David |
09-06-2014, 05:45 PM | #2 |
Rep 3,547
The "red thing" is a special terminal BMW uses that cuts power in a crash. It also has fuses in it. It is held in place by the battery, essentially. It removes like a normal battery terminal. You want to be careful that the replacement battery has terminals in about the same location and is pretty close to the same dimensions. It also needs a vent tube in the same location as the stock battery since it's in the trunk (so the vent is more important). But if the battery is functional equivalent, it should go in fine.
Programming (registering) is a little more complicated if you change the battery type. If you put in the same type and size of battery, it is just telling the car it has a new battery. If I remember right, that is in software called "Tool32". If you change the size or type, you also have to go into NCSExpert to tell the car it's a different size and/or type of battery. If you want to change, you might want to be sure that your little BMW shop can also tell the car about the change in battery. Even $200 for a battery seems steep to me. But bimmer parts are not the cheapest.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
09-06-2014, 09:38 PM | #3 |
Rep 3
JimD thanks for the info.
The $150 was for a lead acid and the $175 was for an AGM battery, both from Auto Zone and both prem. bat. with 3 yr replacement warrenty. I currently have a white battery and it sounds like it is a lead acid. I will research and find the one that matches the dimensions and vent position etc. I read that some of the quick search things for the auto parts stores do not always show the correct battery. Thanks again, DD |
09-09-2014, 03:14 PM | #4 |
Rep 64
Drives: 08 E88 135i
I replaced my lead acid battery with the autozone AGM one (IIRC the H8 one) and it fits fine. The vent tube plugs in easily, although at my autozone for whatever reason the H8's didn't come with a plug for the second vent hole, while all the other sizes did, so either make sure you find one that has one or just grab it off another size (which I did after I pointed it out to the guy there).
I did the programming/registering myself, so the total cost was 179 minus the core for a new battery. |
10-25-2014, 06:25 PM | #5 | |
Rep 210
thanks!
'11 135i M-Sport DCT, M3 RSFB, PPK, CP, BMS intake, Agency Power Axle Back, VRSF 5.5" FMIC, FSB, M3/M1 Front + Rear Control Arms, Ground Control Coilovers, Ground Control Camber Plates, E92 M3 Front Seats, VMR 701's Squared 255's, E92 M3 Steering Rack - Daily Driven, Occasionally Tracked - 157k miles <SOLD> >2021 HS M2C Manual
04-29-2015, 08:47 PM | #6 |
Rep 381
I second this
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000 2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive |
04-29-2015, 11:08 PM | #7 |
bimmerphile, technogeek
1000
Rep 3,785
Drives: 2012 E82 6MT Sport
Two choices:
1. Bluetooth OBD2 dongle and BMWhat app. 2. OBD2 USB dongle/cable and NCS Expert.
04-30-2015, 06:03 AM | #8 |
Rep 1,026
04-30-2015, 08:18 AM | #9 |
1000
Rep 3,785
Ah, true... I never think about Apple products.
