proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      09-14-2014, 08:35 PM   #1
Onetime237
Drives: 335
AC/Heat Fan Power
I know there's been an earlier thread on some AC issues... My problem is the power of the fan - it's just weak. Temp is fine - the air flow is poor unless I keep it at the top setting...which still is not super powerful for the last fan level. I took mine in to get looked at...they said it was similar to other vehicles they've seen. There's just no power...It's like something is blocking the air (which technically nothing is).
Anyone else have this issue?
      09-14-2014, 08:43 PM   #2
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
If you don't even know if you have an M4 or an M3, how do you know how to operate the A/C?
I've had a similar thing with my M4...tinted shop job. I reset all the vehicle data - MPG consumption, etc. I dropped the car off at 22.6mpg and got it back with 16.2mpg. The odometer had not changed. So, on one hand they did not drive it, but they may have redlined it to hear the note.
M3 BSM here...
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      09-14-2014, 08:48 PM   #3
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
I closed the rear vents which helped air flow.
      09-14-2014, 10:04 PM   #4
Onetime237
Drives: 335
Typo. Thanks for your insight.
      09-15-2014, 07:10 AM   #5
celler
celler's Avatar
14
Drives: F80 M3
Tapping the right Max AC knob has been enough for the Florida tropics so far. 90-98 degree weather after sitting in the sun for a couple of hours.
      09-15-2014, 10:38 PM   #6
Racer20
Drives: F80 M3, 228i THP, E46 ZHP
When the AC is set to auto, the fan speed buttons set the max fan speed for the auto mode. When my car was delivered, it was set to the lowest speed. So in auto mode, it never went above the lowest setting.
Hit the fan speed up button a few times and you'll get higher fan speed when you need it.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
f80post
