09-21-2014, 06:14 PM | #1 |
Rep 258
Best Air Compressor/Tire Repair Kit for Non-RFs.
What air compressor and tire repair kits are you all using when you elect to use non-run flat tires?
Here is one made by Slime. http://www.slime.com/shop/power-spai...air-kit-70004/ |
09-21-2014, 11:44 PM | #3 |
Rep 1,133
Here's what I use, except I don't use the tire sealant in the mobility kit. Too much of a mess and I don't want to risk damage to the wheels sensors. The Dynaplug Pro kit is amazing and it's really easy to use. Best of all it works
http://www.shopbmwusa.com/PRODUCT/342/BMW-MOBILITY-KIT/ http://www.dynaplug.com/products.html |
09-22-2014, 05:24 AM | #4 |
Rep 258
Thanks for the info and links.
I didn't know BMW had an oem air compressor. What is the quality of the compressor? Is it fairly quiet? The BMW tire sealant is latex and they say it will just wash off. Is there still risk to the tire or tmps sensor? If I have a plug kit will there ever be a need to use the tire sealant? If under any circumstances, the latex sealer will not be used, then how do you think this compressor looks: it is tiny, runs cool via a fan and has a very accurate and easy to read psi tire gauge. http://www.dynaplug.com/inflator.html How do you think the Dynaplug compressor compares to the BMW oem compressor? Which Dynaplug tool did you get? Did you get plastic, the stainless steel or the feather light aluminum? The Extreme looks good with its wide handle base. Thanks Last edited by SUV55; 09-22-2014 at 06:15 AM.. |
09-22-2014, 07:38 AM | #5 |
Rep 403
I carry - but have not had to use - the continental kit.
http://www.sportsimportsltd.com/coti...FWoR7AodGyIAig Have had 3 plugs in my real tires and it has been great to get them fixed, not replaced :-) |
09-22-2014, 09:33 AM | #6 | |
Rep 1,133
It's good to be bad
09-22-2014, 11:35 AM | #7 |
Rep 111
BMW says you cannot plug or patch RF tires, is this true?
I personally think this is BS so the consumer has to buy a new tire. I know you don't want to drive on a patched tire for years-on-end because water will rust out the belts and degrade the tire. But I am not too worried, I have yet to get much more than a year out of a set of tires. |
09-22-2014, 12:13 PM | #8 |
Four stripes vehicle commander
159
Rep 206
Rep. kit
I don't know if it's the "best" really, and regardless of this thread, today I picked up my original BMW tire-kit, ordered a few days ago.
Preparing for the unavoidable winter I haven't researched, but was told by the dealer that the new part-number for this kit is now: 71102333674. Hope I will never need it Best Bent |
09-22-2014, 12:13 PM | #9 | |
Rep 1,886
AMAZON |
09-22-2014, 01:54 PM | #10 | ||
Rep 1,133
It's good to be bad
09-23-2014, 06:13 AM | #11 |
Rep 258
Good info on this thread, thanks for all the responses. One more question, if I go with the Dynaplug air compressor and plug kit, can get a separate latex sealer spray that is self pressurized that doesn't need to work through the compressor?
With 20's on the rear...they are wide and it will be a tight fit to get a my hand to the inside portion of the tire, remove a nail, then plug it. In this scenario, I think it would be best to have a latext spray handy. Unlike the BMW oem, the Dynaplug kit does not have a latex spray option. It seems that as long as the spray is latex and water based, it will not harm the tire or tire sensor, correct? If I buy the BMW oem latex sealer tank, will it likely work if I connected it to the Dynaplug air compressor? Here is a stand alone option: http://permasealtire.com/ Last edited by SUV55; 09-23-2014 at 06:25 AM.. |
09-23-2014, 02:55 PM | #12 |
Rep 2,091
Great thread! I will likely pick up this Dynapro and keep it in our soon to be ordered X5 as I plan to switch to Conti DWS once OEM 20s wear out.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
