09-22-2014, 08:18 PM | #1 |
Rep 781
Question about M sport handling
I really like the look of the M Sport, but don't want a hard ride. Is there any difference between the M Sport suspension and the other models that make it ride much harder without ordering any of the suspension upgrades?
09-22-2014, 08:22 PM | #2 | |
Rep 342
09-22-2014, 08:32 PM | #3 |
Rep 3,990
Despite what anyone else tells you, unless you get bigger wheels, you'll have much more body roll/looser cornering with the stock suspension compared to M-Sport suspension or DHP. My recommendation...get DHP if you can afford it.
2014 X5 50i X-Line // Mineral White
09-22-2014, 08:46 PM | #4 |
Rep 512
In comfort setting and 19" wheels the ride is really,really good. Sport mode the ride is firmer but not harsh by any means and it handles like a well tuned sport sedan.
09-22-2014, 09:00 PM | #6 |
Rep 971
09-22-2014, 09:45 PM | #7 |
Rep 137
I have M adaptive suspension option added and glad I did. In comfort mode the ride is very comfortable without being floaty. The nice thing is you have the option to switch to Sport mode if you needed better cornering and the suspension does tighten up a little, again without being harsh. This is with 19 " wheels.
09-22-2014, 10:36 PM | #8 | |
Rep 3,307
But first, in case it isn't clear from the other posts, getting an M sport line does not change the suspension, it's the standard suspension unless you add the suspension options too. So you. CAN choose M sport line without the stiffer suspension options. You can, but you shouldn't... I too skipped the suspension upgrades because this is my wife's car and the standard suspension is still pretty good. Pretty good for an SUV, but definitely does have too much body roll. So I regret not getting the upgrades. Like others have said, you can always use comfort when you want it softer. |
09-22-2014, 10:43 PM | #9 | |
Rep 3,990
09-22-2014, 10:48 PM | #10 | ||
Rep 3,307
09-22-2014, 11:20 PM | #11 |
Rep 3,990
Ah, that is annoying . I feel your pain, though. I wish I built my car now since I don't have it after buying it on the lot.
09-23-2014, 08:04 AM | #12 | |
Rep 5,066
I always build my own BMW to my own specifications Same thing can be said with other manufactures. |
09-23-2014, 09:18 AM | #13 |
Rep 286
Different strokes for different folks, I guess. Wifey and I tried out the M50d with M-sport suspension settings, and hated the bounces - too firm even in Comfort mode. Can't imagine how the passengers in the 3rd row (we were looking for a 7-seater) would feel! Settled on the air-suspension "Comfort" option on an xDrive35i instead. Taking it home in a week's time, just in time for my birthday!
09-23-2014, 11:24 AM | #14 | |
Rep 781
Standard - 0.4" lower on the M sport, same ride, or slightly firmer Adaptive M = + $900 to the build and gives damper control and air rear axle Dynamic Damper + $1500, gives damper control and Air rear axle Dynamic Handling - added $4500 to build on M Sport - gives active roll control and thrust vectoring rear axle I am having trouble understanding the difference between Adaptive M and Dynamic Damper control since the explaination for each on the build site says damper control and air rear axle???? Adaptive M for $900 seems to be a better choice in terms of bang for the buck |
09-23-2014, 11:38 AM | #15 | |
Rep 3,307
There is a Sticky outlining the different suspension options (also based on 2014 model): http://f15.bimmerpost.com/forums/sho...d.php?t=913797 As a side note, I still can't believe the $4500 bucks for DHP doesn't include the active steering. That's one more sign to me that the "Active Steering" on the X5 is not intended to stiffen up the steering feel like the "Variable Sport Steering" on the F30 (which is included in the DHP for the F30). But I've read comments from people on here with the Active Steering that say it does tighten up steering feel when they put it in sport mode. That happens slightly without Active Steering, but some do seem to feel it does that even more-so with AS. Anything but simple… They need to find a better way to make more direct connections with these options. Maybe add more driving modes or something when you have the suspension upgrades (maybe sport, sport 1, sport 2 sport 3… or something instead of just sport and sport +, with different things happening within those and within comfort based on options you do or don't have). Last edited by chrisny; 09-23-2014 at 11:55 AM.. |
09-23-2014, 11:46 AM | #16 | |
Rep 360
Drives: 1M; E90 M3 ZCP; M4 GTS
Dynamic Damper + $1500, gives damper control and Air rear axle My interpretation is it is either Adaptive M or Dynamic Handling for upgrades over the M-Sport standard suspension. Clear as mud; their ordering guidelines leave a lot to be desired from a clarity standpoint.
-kskpsu
09-23-2014, 11:58 AM | #17 | |
Rep 3,307
+1 to the "lot to be desired too" lol |
09-23-2014, 12:10 PM | #18 | |||
Rep 5,066
I've read here or maybe it was on bimmerfest forums that it does lower. Here are some links that mentions the suspension lowers itself when active. Albeit its not a F15 http://www.bmw.com/com/en/newvehicle...uspension.html http://autoweek.com/article/car-news...ris-motor-show Quote:
09-23-2014, 12:20 PM | #19 | |
Rep 3,307
By comparison, the F30 Sport and M sport lines will add a stiffer, lower suspension (unless you get an x-drive, which is another point of confusion, and also infuriating), the "Sport Suspension." You can then add the adaptive M on top of that. For whatever reason, the F15, as well as at least '13 E70's, adding the M sport option does/did not give you a sport suspension. I've always hated that.. how can a sport package NOT give you a sport suspension….!! |
09-23-2014, 01:36 PM | #20 |
Rep 5,066
I see. Yes I know what you mean... my E60 with sports package ( which really meant something!!! ) had the sports suspension that was slightly lower that was equipped with EDC damping controls and ARS anti roll stabilizers...
09-23-2014, 01:46 PM | #21 | |
Rep 781
09-23-2014, 01:51 PM | #22 | |
Rep 781
