09-27-2014, 05:25 PM | #1 |
Rep 2,972
Poly Differential Bushings
There appears to be 2 companies who offer Polyurethane differential bushings for the E9X's; Powerflex & AKG. Looking for feedback from those who have gone this route vs solid or derlin. The latter 2 do not seem a viable option on what still remains my daily driver.
Powerflex is produced in one of three durometers: yellow (70A – stiffer than rubber), purple (80A), and black (95A – very stiff) AKG looks to offer two options: red (75D- recommended race application), and black (95A) Do Polyurethane bushings require "maintenance" or develop noise? |
12-19-2014, 03:25 PM | #2 |
Rep 999
Oh man did a quick research and derlin bushings and seems like it's NOT the way to go! Haha (I was curious about them) That being said I want the poly ones but need some reviews also ^^
Bump
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
12-19-2014, 08:00 PM | #3 |
Rep 10,668
I am going to use AKG poly diff and subframe bushings. Have not decided yet on 95A or 75D. Might put 75D in one location and 95A in another. 75D is close to delrin.
I run AKG 95A diff bushings in my turbo 99M3 with Powerflex 80A subframe bushings and noticed no NVH increase. So I will go stiffer for the E90M3. |
12-20-2014, 10:29 AM | #4 | ||
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
With the poly differential bushings, maintenance shouldn't really be necessary. I would expect a slight increase in whine, but certainly not as drastic as solid aluminum or delrin. Quote:
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
02-10-2015, 02:00 PM | #5 | |
Rep 1,479
Drives: 2017 F80 M3
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
02-10-2015, 02:05 PM | #6 |
Rep 1,122
Just ordered some 95a akg poly diff bushings that I'm going to have installed with my solid subframe bushings. Will report back on nvh.
Matt Fojtik133.00 |
02-11-2015, 12:19 PM | #7 |
Rep 3,742
02-12-2015, 11:29 AM | #8 |
Rep 19
just installed the akg street version, small increase in whine and firmer over expansion joints on bridges. but def feels better and rear doesn't shimmy. worth it.
Matt Fojtik133.00 |
02-12-2015, 12:02 PM | #9 |
Rep 3,742
02-12-2015, 12:03 PM | #10 |
Rep 875
I am assuming you installed all 3? Did you DIY or pay a shop to do it? Powerflex sell the front 2 and the rear 1 separately. Wondering since only the rear one is foam if we can just replace the rear one with poly and that will be enough to help while not adding any nvh. Thoughts?
02-12-2015, 04:19 PM | #12 | |
Rep 386
02-12-2015, 06:32 PM | #13 | |
Rep 875
02-12-2015, 10:25 PM | #14 | |
Rep 386
I believe the same logic applies as I stated above, though. The stress will have to be transferred elsewhere once the solid bushing is installed. I guess without engineering analysis it's hard to say what might happen. Maybe this is the magic formula though? |
02-12-2015, 10:37 PM | #15 |
Rep 1,083
I had Powerflex Purple Diff Bushings and Turner Subframe Mounts installed together. There's a lot of low speed clink clank clunks, especially in start stop traffic. In speeds above 70km or so there would be a whine/whistle that begins. The car's rear def. feels more planted, and the trade-off for the noise isn't too bad.
02-13-2015, 01:34 PM | #17 | |
Rep 19
02-13-2015, 02:13 PM | #18 |
Rep 3,742
02-25-2015, 07:38 AM | #20 |
Rep 1,179
[QUOTE=ashtaron14;17392261]
I had Powerflex Purple Diff Bushings and Turner Subframe Mounts installed together. There's a lot of low speed clink clank clunks, especially in start stop traffic. In speeds above 70km or so there would be a whine/whistle that begins. QUOTE] That's odd as several other owners on this site with the poly bushed diff and solid subframe bushes have said there are no additional noises. I wonder if your installer tightened up the subrame to the body properly? Would you be able to post up a video of the noises pls? I'm looking to install the same items but do not want to suffer from clunking noises. |
03-16-2015, 12:53 PM | #21 |
Rep 2,991
I found the whine of Delrin diff bushings to be intolerable. The subframe bushings made a huge difference and trivial NVH by themselves. I would do the subframe bushings first - you can always go back and do diff bushings later (they don't require dropping the subframe to do)
03-16-2015, 07:28 PM | #22 |
Rep 887
So Powerflex Purple is 80A and AKG street is 95A?
Interesting part is one member reports very little added NVH with the 95A diff bushings and the other with 80A Powerflex reports more clinks/clack NVH. Both have solid subframe bushings. The variable could be fricition modifiers in the differential unit. Doesn't the newer fluid have higher friction modifiers to quiet the rear diff down? Maybe some of the added NVH from the older style fluid is magnified with any amount of stiffer bushings? I'm curious as I would like to do the Powerflex with hopefully little added NVH. The subframe bushings can wait since those would have to have the subframe dropped. |
