09-29-2014, 08:44 AM | #1 |
Rep 56
What is the best brake fluid for 1m
Hi,
I just did a track day with my 1m and I boiled my brake fluid. I was using the stock bmw brake fluid. I need to change it and i want to upgrade it for something better since i plan on doing other track day before the end of the season. Im currently running stock car with upgraded brake pad (Performance Friction Z rated) and square setup Nitto NT01 275/35R18. Thanks |
09-29-2014, 09:20 AM | #2 |
Rep 220
I have Motul 600 in my car and it gets the job done with no boiling. Castrol SRF is considered by many to be the best. I have never been able to justify the price when Motul gets the job done for substantially less $$.
09-29-2014, 09:20 AM | #3 |
Rep 4,531
First off, The pad you're using with the tires is a bad combination.
I'm certain you boiled the fluid, but with upgraded fluid you may very well have pad fading. Be warned. |
09-29-2014, 12:59 PM | #4 | |
Rep 11,785
What Kgolf said. Norm1m Your tires are track tires and your pads are for intermediate track duty at best. I have no issues at all with OEM fluid on track with street tires and even R tires and I have used the same PF-Z pads. I would imagine that you are likely over braking in brake zones, causing excessive heat buildup in the pads and rotors and thus boiling the fluid. You can definitely Upgrade your fluid. Castrol SRF is absolutely awesome. Motul works well also. You can upgrade pads as well, but I agree this could be dangerous. Before you make any changes other than fluid, you need to learn to manage the brakes better and brake less. You didn't indicate your experience level. Was this your first event or have you been to the track in the past? |
09-29-2014, 02:13 PM | #5 |
Rep 56
I'm kinda new at this. Strated lapping this summer and I'm at my 7th track day so far.
One thing you need to know is this track i just did is really rough on brake. It as a long straight line with a top speed of around 215 km/h with a braking down to around 120 km/h for the right corner. We are planning to go track at Canadian Tire Motorsport park near Toronto in 2 weeks. What kind of brake pad i should use ? Keep in mind that this car is also my daily driver. |
09-29-2014, 05:07 PM | #6 | |
Rep 11,785
Unfortunately the next stop (pun intended! ) is full on track pads! At Circuit of the Americas the back straight I reach 235 kph and brake to about 105 kph. I don't have any issues using the same PF -Z pads and Bf Goodrich R1s. There are plenty of other long straights at COTA ... so some times it's not about absolute speed in any one section of the track, but how many other fast or slow sections are on the course.. The two tracks I have been to that are the hardest on brakes are short courses under 1.8 miles (Eagles Canyon and Hallett motor racing circuit) and speeds are never over 200 kph. I imagine you are likely experiencing one of the following two issues that many intermediate drivers come to.. 1- braking too long - i.e - not compressing braking so that you are braking as hard as possible, for the shortest amount of time possible 2- over slowing the car - i.e. - braking too long by slowing the car too much... as opposed to braking less, and carrying more speed *through* the corner. Both of the above will result in more heat in the brakes than is necessary... and multiple laps doing so will eventually end up with brake fade or bioled fluid. To go faster, one should actually brake *less*.... which sounds counterintuitive, but is not. The less time braking, the quicker the lap time. If you have develped your current skill level by primarily attending lapping days without an instructor, I would recommend riding with another driver in a similar vehicle (if not a 1M,... then another BMW at least).. or having an instructor ride with you to have them review your braking. Last edited by M3 Adjuster; 09-29-2014 at 05:36 PM.. |
09-30-2014, 03:27 PM | #8 |
Rep 82
01-04-2015, 02:58 PM | #10 |
Rep 2,819
Drives: e82 1M, f87 M2cs
I have 2liters of ATE superblue and was planning to use it for tack days this year. Is it even worth the effort, or is it comparable to the stock fluid? Maybe I should just track the car the first time on the stock fluid and see how it goes . . . stock car, street tires, fluid replaced by dealer last fall.
01-04-2015, 06:54 PM | #11 | |
Rep 2,898
Neil |
01-07-2015, 09:15 PM | #12 |
Rep 2,819
