ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      10-03-2014, 10:32 PM   #1
RobRed
ID10T Specialist
90
Drives: F90 | F97
First Service Done.... plus TSB
Took my m4 to Mt View today for first service (1550 miles)
Drop at 8.45a and pick up at 4pm.
- Car Wash
- Engine oil
- Diff oil
- TSB campaign 10061130400 - CAN Terminator
So interesting side note... When the lot boy was retrieving my car it sounded loud, similar to cold start in the morning. I jumped in and drove away but the car exhaust note continues to be louder than before. The car is a tad peppier than before as well (not like it was lacking). At first I thought I was dreaming it but then I picked up my girl friend and she said spontaneously that it was louder so it's not just my mind going.
Any ideas why the exhaust note would change? Valves stuck open suddenly. secret software flash? I wasn't told about.
Also I previously tried to use launch control (before service) but I could never get it to come up. I mentioned to the service writer but there was nothing they did supposedly to enable it - he said it's there and implied I may have not done it right.
      10-03-2014, 10:36 PM   #2
RobRed
ID10T Specialist
90
Drives: F90 | F97
Crap wrong forum - mods pls correct my error and move to appropriate forum.
      10-03-2014, 11:29 PM   #3
gogoevo
Drives: 2011 Porsche 997.2 TTS
They didn't recall the OE exhaust and replace with MPE did they? Because that would be awesome. I kid of course, but......
      10-04-2014, 12:02 AM   #4
dclowd9901
dclowd9901's Avatar
Drives: 2015 AW M3
Weird. Your recall number doesn't come up on http://www-odi.nhtsa.dot.gov/owners/SearchResults -- that's where I'd expect to see more info. No other standard service stuff should have any effect on the exhaust. Check with your dealer and keep us posted.
ED 11/3/14 2015 M3, AW, SO, DCT, 19" blk wheels, HK, Lighting/Exec/Tech packages, ad. susp.
      10-04-2014, 10:17 AM   #5
biggie27
could be your exhaust has broken in....if that makes sense usually it takes time for an exhaust to break in and it does sound louder with a few miles on it........or the turned up the speakers in the car :P
      10-04-2014, 10:51 AM   #6
RobRed
ID10T Specialist
90
Drives: F90 | F97
I doubt it broke in more from the morning to the afternoon
The sound increase is from outside the car. I'm not complaining but it's interesting.
I'll post a photo in the top of the thread of the service order for the CAN recall.
      10-04-2014, 12:55 PM   #7
Hobbination
Hobbination's Avatar
Drives: 2015 M4
Launch Control only works after they program it in, after the 1st service.
      10-04-2014, 02:32 PM   #8
Gac101177
M4-SAHD
Gac101177's Avatar
512
2015 BMW M4  [10.00]
Thanks I'll let my advisor know, I'll be doing my service on Monday
      10-04-2014, 03:09 PM   #9
RobRed
ID10T Specialist
90
Drives: F90 | F97
I specified to program launch control in my service request. I would have expected to see a line item on work order for it. It did not have it.
I will test for it again today to see if it's working. They did reset my service interval... apparently I have break in maintenance due in 1200 miles LOLz
      10-06-2014, 11:56 AM   #10
Gac101177
M4-SAHD
Gac101177's Avatar
512
2015 BMW M4  [10.00]
- Car Wash
- Engine oil
- Diff oil
- Recall campaign 10061130400 - CAN Terminator
Thanks for the info, my it's today told my adviser and he said yes they will do the recall
      10-06-2014, 04:24 PM   #11
michaelw9
Drives: 2015 F82 Yas Marina Blue M4
They have to use their full diagnostic equipment to reset the break in service indicator, otherwise you'll see another break in maintenance due in 1200 miles listed in your iDrive. And the Launch Control is not active until that is done. They did not follow the proper procedure to reset the indicator. (This happened to me also) Given that they didn't read the F8x break in service procedure, hopefully they also changed your oil drain plug AND the two differential drain plugs, as they're supposed to be replaced each time they are opened up.
      10-06-2014, 05:11 PM   #12
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
Can someone say what the "recall" is?
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      10-06-2014, 08:58 PM   #13
Gac101177
M4-SAHD
Gac101177's Avatar
512
2015 BMW M4  [10.00]
My car it's at the dealer as we speak, yes there it's an sib on the car.
I ask a friend that happens to be a master mechanic at the dealer what this was he's answer: its called a terminal resistor It was just not installed at the factory On a short production run of cars its there to protect from over-voltage
      10-06-2014, 09:10 PM   #14
SakhirM4
SakhirM4's Avatar
2015 BMW M4  [8.76]
So, it is not a recall after all, just a service bulletin. Thanks.
      10-07-2014, 11:14 AM   #15
RobRed
ID10T Specialist
90
Drives: F90 | F97
Yeah - Sorry I should have not used the term recall... TSB and upgrade.
Corrected original post.
      10-07-2014, 01:00 PM   #16
Gac101177
M4-SAHD
Gac101177's Avatar
512
2015 BMW M4  [10.00]
Sorry for what bro, thanks mine was done thanks to you post, dealer didn't have a clue there was a bulletin, got my car back and it does sound different better.
      10-07-2014, 01:44 PM   #17
Sal@AUTOcouture
BimmerPost Supporting Vendor
Sal@AUTOcouture's Avatar
733
Drives: E93 M3, E36 M3
Spoke to our friend in service and looks like it's nothing serious. Apparently some 4-series are missing a particular CAN terminator resistor and are causing false electrical faults in the DME.
      10-07-2014, 06:12 PM   #18
RobRed
ID10T Specialist
90
Drives: F90 | F97
Recall and TSB have different connotations that's all.
Glad you got it done AND glad it's not me only that noticed the sound change. If you're DCT you may also find the shifting has improved - S2 quicker and smoother, S3 less jerky / smoother. This little part must have been a bigger deal than I was led to believe.
      10-08-2014, 03:05 PM   #19
RobRed
ID10T Specialist
90
Drives: F90 | F97
Update:
Had the service reminder corrected and Launch Control is confirmed Best to use comfort on shocks for launch keeps wheel spin/chirp down.
Spoke to BMW more about the CAN terminator and it's a big deal to the cars affected. My M4 is dramatically improved post install. Also confirmed the sound change as an effect of this update. Obviously if you car is not one of the campaign cars you've already had the better sound and driving. Lucky you.
      10-08-2014, 03:42 PM   #20
bqn109com
Drives: 15' F82 M4,07' E60 M5,12' X5M
Sorry.. What is a campaign cars? My car finished production on 9/11/2014. It's on the boat now, would that affect me?
Thanks,
Bert
Update:
15' M4 YMB w/ SO, MP black trim, MP Aero kits, Vorsteiner rear diffuser, 20' Vorsteiner VFF 102 Carbon Graphite w/P Zero, Full nose clear bra, KW HAS spring)
Current: 07' M5 e60 RPI mod, 12' X5M (wife)
Current: 56' Porsche 356 Speedster, 12' Prius C, 90' Miata
      10-08-2014, 05:31 PM   #21
RobRed
ID10T Specialist
90
Drives: F90 | F97
Thanks,
Bert
"Campaign" cars are VINs affected with this particular parts replace campaign.
My production date is 6/17 so if the parts are in the field I would guess your's is not affected. Only way to know is look at the bulletin and see if you VIN range is is listed.
      10-12-2014, 02:53 AM   #22
kinimod
Drives: 911 GT3
Can you guys post the bulletin? Would love to check against my VIN.
Awesome info here, thanks.
f80post
