10-08-2014, 02:32 PM | #1 |
Rep 2,928
Drives: 328i, 335i, M3, 535i, X5, 36M
Garage List 2014 Ford Raptor [0.00]
2012 328i E92 [10.00] 2013 X5 [0.00] 2013 335i F30 [8.00] 1990 Toyota Previa [0.00] 1997 E36 M3 [10.00] 2011 E92 M3 [0.00] 2011 535i [0.00] |
Rear facing car seats in F80
Those of you who use it as a family car, do these fit ok? Can they be attached to the center rear seat instead of behind the driver or passenger?
I just installed the rear facing seat in my X5 and had to push the passenger seat all the way forward or the carrier wouldnt fit because the back of the carrier would be squished in between. F80 family car is on order so I've no idea if this will fit or not. Can those of you who have tried it chime in? Also for sedans are there metal latches in the rear seats for center installation? i only saw latches on the left or the right... |
10-08-2014, 03:45 PM | #2 |
Rep 186
Yes, you can put the seat in the middle and use the inner latches from each side seat. My wife has a 2013 328i and that's how we do it so the front seats don't have to be moved forward and the center is the safest for the baby. I researched it a lot ahead of time. The latches just need to be something like 11 inches apart or more to be used properly. I measured the two inner latches at about 12 inches apart.
10-08-2014, 06:02 PM | #3 |
Rep 1,147
You'll have no problem hooking up a baby seat inside your M3. If you do it behind the shotgun seat there will be sufficient space for your wife up front unless she is of beastly size. Also stroller fits in the trunk without a problem.
10-08-2014, 06:48 PM | #4 | |
Moderator
7525
Rep 19,368
Certainly there is an upper limit to how far apart the anchors can be while still being able to safely secure the seat. Now twelve inches may very well be within that limit, but I would defer to BMW on this. |
10-08-2014, 07:19 PM | #5 | |
Rep 6,780
10-08-2014, 08:13 PM | #6 | |
Rep 348
In all my other cars, including BMWs, the manual states not to use the outside latches for a car seat in the middle. I haven't checked my M3 manual yet. |
10-08-2014, 09:55 PM | #7 |
Addicted to Speed.
714
Rep 2,375
I am thinking of ordering an m4..... expecting having kids in the next 1-2 years.. am i crazy for not going m3? the m4 looks so much better but I am concerned regarding the rear facing seat....
2017 991.2s
2015 F15 35i 2017 Macan gts |
10-08-2014, 10:08 PM | #8 | |
Rep 373
10-08-2014, 11:20 PM | #9 | |
Rep 111
10-09-2014, 12:33 AM | #10 |
Rep 1,147
10-09-2014, 12:35 AM | #11 |
Rep 1,147
You'll be fine. Also you can always sell the M4 then and pick up something bigger if it becomes a pain in the ass.
10-09-2014, 06:12 AM | #13 | |
M4-SAHD
512
Rep 611
10-09-2014, 09:07 AM | #14 | |
Rep 6,780
All the cars I've had our rear facing seat in significantly compromised my wife's legroom. Granted she's tall, but it was to the point where even someone shorter would have noticed. I can't even imagine something like a Graco seat in a B6 S4 behind the passenger. That's one small seat if you were even able to get someone in front of it. |
10-09-2014, 11:18 AM | #15 | |
Rep 75
10-09-2014, 11:47 AM | #16 |
Rep 2,928
so can we confirm if on the rear facing seat we can use the two inner latches and stick the baby seat in the middle so neither driver or passenger leg room gets compromised?
my f30 ended up getting lemoned before i had the car seat so no way to confirm |
10-09-2014, 02:57 PM | #17 | |
Rep 194
We have the Combi Coccoro and it fits great. It's designed specifically for small cars like Civic, so it should give you plenty of room. We had it in our E46 M3 and E90 M3 and there were plenty of room. http://www.amazon.com/Combi-8220105A...=combi+coccoro
01 740iL 06 M3 CB/black ZCP M6
17 Ford Focus RS 21 JLUR Sarge Green/black M6 21 STI WRC Blue 24 D110 P400 White/black |
10-09-2014, 10:58 PM | #19 |
Rep 2,928
Too late I already have a nuna pipa
10-10-2014, 06:30 AM | #20 | |
Rep 1,147
10-10-2014, 08:44 AM | #21 |
Rep 6,780
Yeah, that seat looks tiny compared to most Graco and Britax products I've seen.
