10-20-2014, 03:43 PM | #1 |
New Lifetime Replacement Policy
821
Rep 11,738
:: ECS Tuning :: Introducing The ECS E8X Rear Trailing Arm|Stronger Lighter
While the BMW E8X is capable of sustained, high-performance driving, its suspension system is not without flaws. Specifically, the rear trailing arm fitted to these models has a tendency to fail without symptoms, potentially leaving you stranded without a critical suspension component. ECS has solved this issue with a meticulously engineered Performance Rear Trailing Arm, made from aluminum & better designed to withstand the demands placed on it. Not only is the unit more robust & dependable than the factory unit, it's also lighter, reducing weight. •Constructed from solid 6061-T6 aluminum• •Anodized for corrosion resistance• •Increased strength versus the factory steel arm - this arm fears no pot holes• •25% lighter (384 grams versus 517 grams each)• Click HERE for your E8X ECS Performance Rear Trailing Arm Upgrade |
10-21-2014, 10:46 AM | #2 |
821
Rep 11,738
10-21-2014, 02:49 PM | #3 |
821
Rep 11,738
10-22-2014, 09:49 AM | #4 |
821
Rep 11,738
10-22-2014, 02:42 PM | #5 |
Rep 639
Just ordered a set.
2009 BMW LeMans Blue 135i/Dinan Stage 2 tune/Alufelgen SF-71s/M3 suspension components/Koni Sport adjustable dampers/ETS FMIC/M3 paddle shifters/Alpina B3 TCU flash/VRSF charge pipe
12-12-2014, 02:26 PM | #8 |
821
Rep 11,738
12-30-2014, 03:09 PM | #9 |
821
Rep 11,738
03-25-2015, 11:39 AM | #10 |
821
Rep 11,738
03-31-2015, 11:01 AM | #11 |
821
Rep 11,738
04-16-2015, 11:39 AM | #12 |
821
Rep 11,738
04-16-2015, 03:26 PM | #13 |
821
Rep 11,738
07-28-2015, 12:45 PM | #14 |
821
Rep 11,738
07-29-2015, 10:43 AM | #15 |
821
Rep 11,738
10-02-2015, 04:31 PM | #16 |
821
Rep 11,738
12-14-2015, 12:04 PM | #17 |
821
Rep 11,738
12-14-2015, 04:16 PM | #18 |
821
Rep 11,738
02-08-2016, 03:04 PM | #19 |
821
Rep 11,738
