Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      10-25-2014, 08:49 PM   #1
sherm
Drives: '15 BMW M4
Help!! Dropped bolt in engine bay!!
My brother dropped a bolt in the engine bay while trying to install a new air filter. We haven't tried starting the car because we're afraid to in case it could screw something up.
It's now too dark to try to look for it but does anyone have any suggestions as to what to do?
///M4 | Alpine White | Sakhir Orange Leather | Carbon Fiber Trim & Roof | DCT | Black 19" Wheels | Executive Package | Driver Assistance Plus Package | Adaptive M Suspension | Enhanced USB | Parking Assist | Harman Kardon
      10-25-2014, 08:54 PM   #2
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
It'll probably fall out with continued driving. Or it gets caught in underbody shield
      10-25-2014, 09:02 PM   #3
sherm
Drives: '15 BMW M4
Isn't it unsafe to drive with a bolt somewhere in the engine bay? I don't know if it hit the bottom..
      10-25-2014, 09:04 PM   #4
C-ARchitect
Drives: Miniature Ferrari
Take out the undertray because most likely the bolt should be sitting at the bottom or use a magnetic stick and poke it around the engine bay until it catches.
      10-25-2014, 09:19 PM   #5
Wei718
Wei718's Avatar
340
Drives: 718 GT4
As suggested from above, remove the under tray and look for it. If you need to start the car don't worry, nothing will happen for a missing bolt from the intake box as long as the sensors isn't disconnected you will be fine.
      10-25-2014, 11:42 PM   #6
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
If you don't know the answer to this question, you probably shouldn't be working around the engine.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      10-25-2014, 11:46 PM   #7
NorCal f80
Listen for the bolt while hitting the undertray with your hand. I wouldn't sweat it if you can't find it.
      10-26-2014, 12:31 AM   #8
sherm
Drives: '15 BMW M4
Thanks for the tips guys I'm sure he'll find it once we jack it up and use a magnetic stick
      10-26-2014, 05:14 AM   #9
Boss330
Boss330's Avatar
You really don't want a dropped bolt near the serpentine drive belt...
http://www.n54tech.com/forums/showthread.php?t=11957
The S55 should be similar to the above.
Get a bolt in there and most likely the drive belt will snap...
      10-26-2014, 07:19 AM   #10
schmitzna
schmitzna's Avatar
Drives: 2015 M3
2018 BMW X3 M40i  [0.00]
2015 BMW M3  [0.00]
S55 belts are a lot different without the power steering pump
      10-26-2014, 03:01 PM   #11
Boss330
Boss330's Avatar
Good clarification and shows that the S55 has belts much closer to the airbox than the N55 (parts 8 and 9 are positioned towards the right hand side, while on the N55 all belts are on the left hand side)... Even more reason to be careful with loosing bolts down there
      10-26-2014, 04:06 PM   #12
sherm
Drives: '15 BMW M4
It was very nerve-racking but he finally got it with a magnetic stick and a flashlight!
      10-26-2014, 05:18 PM   #13
Boss330
Boss330's Avatar
f80post
