11-05-2014, 09:04 PM | #1 |
Live Hard. Live Fast. Live Fearless. Be Kind
23
Rep 66
Does replacing bearings with coated ones void warranty?
My car is coming up on end of warranty in three months. I was going to buy extended warranty, primarily to cover against failure of engine or DCT; however, I was also planning on replacing bearings as preventative measure too.
BUT, then I started to think...won't replacing your bearing with non-oem, coated ones void your warranty if your engine goes in any way? How about if an independent shop does it with oem ones? I would assume both would void warranty?... Now I am wondering...do you just extend warranty and live with the risk hoping that BMW cover you if it goes, or do you not do warranty and replace bearings to manage the risk? |
11-05-2014, 09:07 PM | #3 |
Rep 2,189
If you get extended warranty do not touch the bearings until it is over. It's like paying for two insurance policies at the same time with one that invalidates the other. They will almost certainly deny you engine warranty work if they found out you had a shop change the bearings.
11-05-2014, 09:12 PM | #4 |
Rep 922
They are OEM, just wpc coated.
If you're going to buy extended warranty to cover power train why not just leave the bearings so you get your money's worth? I understand you want to prevent an issue but that's what warranty is for. Good luck!
'11 Black/Black GLK350 (Wife)
'19 Black RAM 1500 Big Horn Night Package '11 Loaded AW Fox Red/Black/Black Carbon Leather ZCP E90 M3 (Halloween Delivery) |
11-05-2014, 09:13 PM | #5 |
23
Rep 66
No joke, just me overthinking things, like usual...:-0
That's what I thought...either one or the other, but not both....
11-05-2014, 09:15 PM | #6 |
Rep 701
Yeah I understand this is you thinking out loud. But its common knowledge that anytime you open an engine you void the warranty. If you got the extended just drive it until you blow it up. Then you'll get a new engine.
11-05-2014, 09:16 PM | #7 |
Bad Lieutenant
233
Rep 3,517
Treated, not a coating. Agree, don't crack it open unless it's got symptoms.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
11-05-2014, 09:17 PM | #8 | |
Rep 922
11-05-2014, 09:43 PM | #9 |
Bad Lieutenant
233
Rep 3,517
Yeah, some kind of micro-shot-peening treatment. There used to be some sweet videos on their site showing the anti-friction properties.
11-05-2014, 10:19 PM | #10 |
Rep 1,974
This is my plan as well. Going to swap them out once my CPO warranty runs out in '17, unless it happens before that.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
11-05-2014, 10:52 PM | #11 |
Rep 2,271
I decided that I'm not buying extended warranty and simply put the money I would have spent on replacing the rod bearings in a couple of years. Just remember, once your warranty expires, you still have the same old rod bearings and you're back to square one. my $.02.
2011.75 E90 AW | DCT | ZCP | ZCV | ZCW | ZP2 | Prem Sound | Moonroof | BMW Apps |
Mods List: Evolve Exhaust | M Perf Steering Wheel | Tint | Lux | Hardwired V1 | KW V3 | Volshlag CP | Brembo BBK | BBS FI | Yokohama AD08 R| Schroth 4 Point Harness | Challenge GT Diffuser | OEM GTS Wing| GTS Lip| I lied earlier, I wasn't done with mod, but I swear, I'm done now, no more mods... |
11-06-2014, 05:54 AM | #14 |
Rep 3,071
"Agree, don't crack it open unless it's got symptoms" These are? Would an oil analysis help?
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
11-06-2014, 08:11 AM | #15 |
Bad Lieutenant
233
Rep 3,517
Rod knock. Oil analysis doesn't help unless you've been doing for several changes.
11-06-2014, 09:25 AM | #16 |
Rep 589
11-06-2014, 09:29 AM | #17 |
Rep 3,633
Here's a good test>>>
Put car in higher gear at a lower RPM and slightly lugging the engine. Tip into the throttle and if you hear a slight knocking immediately that would be indicative of rod bearings on their way out. |
11-06-2014, 09:32 AM | #18 | |
Rep 734
2. Ask Blackstone, but I suspect you can still learn from the analysis even first test. Certainly less than subsequent tests but still could detect high levels compared to other M3. |
11-06-2014, 10:07 AM | #19 |
Rep 701
Those are only average baselines. Every engine is different. He's correct the best and really only way to know what's going on is to baseline and trend your own engine.
11-06-2014, 10:37 AM | #20 |
Bad Lieutenant
233
Rep 3,517
Copper is the 2nd layer, IIRC, below the aluminum/tin babbitt, so if you see copper, then you may be into them.
11-06-2014, 10:42 AM | #21 |
Bad Lieutenant
233
Rep 3,517
There is a ton of good information in the Rod Bearing threads down in the Tech/Engine section. It's worth a read.
