Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      11-22-2014, 02:44 PM   #1
purdyawesome
purdyawesome's Avatar
26
Drives: 2015 F80 M3, 2014 F15 X5
Can anyone recommend a torque wrench?
Can anyone recommend a specific general purpose torque wrench? I'd like a nice one that will last forever and can do 0-? lbs... Would rather not buy one for low tension applications and another for more... Good quality, decent value - don't need hand forged, damascus steel, bomb-proof... I'm going to drop in some BMC air filters and the cf strut brace is just one of the millions of things I've needed a torque wrench for and not had... Thanks.
      11-22-2014, 03:13 PM   #2
bbellz
bbellz's Avatar
Drives: 2018 BMW M3
I'd recommend CDI. I have a 0-75 and another that goes to 150ft/lbs. I didn't go with the electronic version.
      11-22-2014, 03:16 PM   #3
BMWJ
Drives: 2011 E92 M3
I have one made by Titan - It's pretty good, I used it to swap springs one time and most use it to torque my wheels on and off. I wouldn't use it for building an engine, but for most stuff when you only have to be close to accurate it's good.
      11-22-2014, 03:18 PM   #4
Jockey
Jockey's Avatar
3451
Drives: 992 C4S
Craftsman. Can never go wrong with them.
      11-22-2014, 03:20 PM   #5
dmk08
Gone Fishin’
dmk08's Avatar
Drives: Walks
Seconded. Can get a great deal on one this time of year too.
      11-22-2014, 03:22 PM   #6
Wei718
Wei718's Avatar
340
Drives: 718 GT4
I personally have Craftsman but would recommend snap on or CDI
      11-22-2014, 03:53 PM   #7
purdyawesome
26
Thanks guys - now which "type" of torque wrench? The click kind? or the old fashioned type that guys use in bike shops? Also, will these standard torque wrenches accept a socket to remove our wheels? While I'm at it, might as well kill two birds with one stone - what about a jack? If I want to change out my wheels on my own, what is the best way? I don't want to screw up the side skirts or anything.... floor jack?
      11-22-2014, 04:15 PM   #8
SuckaGDog
Drives: M5, C63 AMG Black Series
I like my Snap-on torque wrench. Here is an eBay ad to the one I use. I use this one for wheels and bigger stuff I need torqued.
http://www.ebay.com/itm/Snap-On-1-2-...=US_Hand_Tools
I have another one that I use for smaller applications.
      11-22-2014, 07:53 PM   #9
FTS
Enjoying driving
FTS's Avatar
Drives: 645
Precision Tools is the best one have used thus far, many different models, excellent service post sales and always precise!
      11-22-2014, 08:11 PM   #10
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
You don't need a high-end torque wrench to do suspension work. Being off by +-3ft lb is fine. Craftsman should be only off about +-4%. The more you pay, the more accurate it gets (like Snap On). Unless you're rebuilding your engine block or heads, you don't need it to be more accurate than that. Save your money and stick with Craftsman, lifetime warranty and no questions asked for warranty swaps.
      11-22-2014, 08:21 PM   #11
bdoooh
Drives: 2014 SSII M5 CP
I dunno if I would actually recommend it but I've had mine from Harbor Freight for years and have had no problems with it. $10 with a coupon from the flyers lol.
      11-22-2014, 08:42 PM   #12
ES_TRADER
Drives: 328i, 335i, M3, 535i, X5, 36M
2014 Ford Raptor  [0.00]
2012 328i E92  [10.00]
2013 X5  [0.00]
2013 335i F30  [8.00]
1990 Toyota Previa  [0.00]
1997 E36 M3  [10.00]
2011 E92 M3  [0.00]
2011 535i  [0.00]
+1, can't go wrong with $10 harbor freight. Use the same one as well. Bought two for the hell of it, cheapness rules
      11-22-2014, 09:40 PM   #13
apexit
Drives: 15 SO M3
This. All you need to know is that Snap On sources theirs from CDI. I have 2 and so far so good. I'd go with the click just to make life easier/ cheaper. Make sure you store it with the tension set at the minimum or you can prematurely wear the mechanism.
      11-22-2014, 09:44 PM   #14
consolidated
consolidated's Avatar
205
Drives: F80 M3
But have a feeling you meant Precision Instruments.
I've been using the 1/2", and 3-piece 3/4" drive tools, split beam design so you don't have to turn it down like the HF and Craftsman's style barrel wrench which will lose it's accuracy and then what good is it for? The wrench is only as useful as it's calibration.
$10 torque wrench? Why bother, I'd trust my muscle memory before those things. I spend enough time at the track to see lugs come off from being under torqued and lugs shear from being over torqued, not worth saving a few bucks over. The 1/2" can be had for $140.
http://www.torqwrench.com/tools/C.php
http://www.garagejournal.com/forum/s.../dp/B002XMSFIM
http://www.amazon.com/s/ref=bl_sr_hi...ts&node=228013
F80 M3 / Mineral Grey-Silverstone / CCB
      11-22-2014, 10:36 PM   #15
Bemo
Bemo's Avatar
Drives: E92M3 LRP Edition
I have this GearWrench model, love it!
http://www.gearwrench.com/torque-wre...50-ft-lbs.html
      11-22-2014, 11:24 PM   #16
FTS
Enjoying driving
FTS's Avatar
Drives: 645
Yes! thank you for correcting me
      11-23-2014, 12:23 PM   #17
bimmerboyE92
I have had the HF one for a while now. I use it mostly for lug nuts but have also used it for suspension on my truck and my lawn mower blades.
I've checked it against a friends snap-on and it "seemed" right on. I've never felt "unsafe" or "unsure" of bolt torque from its use.
If you were going to rebuild a motor, I'd suggest a higher end torque wrench as connecting rod and head bolts require alot more precision. But even then, the manufacturers usually give you a 2-3 ft-lb tolerance.
      11-23-2014, 01:34 PM   #18
bdoooh
Yeah I pretty much use it exclusively on lug nuts haha so I imagine it's fine.
      11-24-2014, 06:34 AM   #19
gsrbri
gsrbri's Avatar
Drives: F87 6MT
Floor Jack
You'll get a lot of opinions here, too.
Regardless - don't forget to purchase the adapter for the jack head to the BMW jacking points, unless you already have it!
http://www.ecstuning.com/ES251251/?g...Fcvm7AodBRYAoQ
      11-28-2014, 01:53 PM   #20
Ging
Drives: m3
Mines got shift lights but did pay $700. Needed when rebuilding S65
      11-29-2014, 06:22 PM   #21
purdyawesome
26
wow. thanks. would have never known i needed an "adapter plate"... good information. so - if i have that, and any sort of floor jack, i'm good to go??
      11-29-2014, 10:05 PM   #22
bdoooh
Yup! If you have a jack with a flat top though, the adapter isn't particularly necessary I feel.
f80post
