11-23-2014, 06:48 AM | #1 |
Rep 43
Cracked manifold??
Hello
I have been recently told by a independent garage that my 2007 E92 M3 has a manifold crack. This was diagnosed by the mechanic though standing by the car and simply listening - so no proper diagnostic yet. He has told me that almost all E92 M3's have this issue and if he was to replace the manifold it would just happen again in 10k - 20k. To me my car sounds like every other E92 M3 at idle. I mean there is a slight ticking/knocking but nothing that really stands out or loud enough to cause concern. Furthermore the car has been into BMW and checked over countless times an they have not picked up on anything... What does everyone else think of this? Thanks! Redmond Last edited by X88RED; 11-23-2014 at 07:34 AM.. |
11-23-2014, 10:39 AM | #2 |
Rep 977
Hey X88RED,
Ticking in the engine bay may be a normal sound for the car, or may be an indicator of rod bearing wear. There are a bunch of videos on this site of the ticking sound and I would listen to those to see how they compare to your sound. I would be more concerned about that than a cracked manifold. I would get a second opinion from another shop. Check out these threads: http://www.m3post.com/forums/showthr...=ticking+sound http://www.m3post.com/forums/showthr...=ticking+sound
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
11-23-2014, 11:05 AM | #4 |
11818
Rep 23,187
11-23-2014, 11:16 AM | #5 |
Rep 1,459
I don think I've heard of a cracked manifold on these cars before, and I can say with certainty it is not a common problem that will come back in 10-20k miles if fixed.
11-23-2014, 11:48 AM | #6 |
Rep 3,633
He's saying its a cracked mani because f the s65 ticking noise. It sounds just like an old v8 with either cracked headers or a leaking header gasket. But its a normal M engine noise.
11-23-2014, 11:55 AM | #7 | |
Rep 24,867
Never heard or saw a cracked manifold .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
11-23-2014, 01:49 PM | #8 |
Rep 1,536
Has this guy ever worked on this engine before? I would bet not. A lot of these "independent master BMW mechanics" never worked on anything beyond 328i's. I had a supposedly very knowledgeable local mechanic ask me if it was a real M3 or a badged 3xxi. I was certain he was joking... he wasn't.
11-23-2014, 10:24 PM | #12 |
Rep 904
Drives: E90
I believe this shows up on the iDrive screen if it were indeed the case
2011 E90 M3 6mt AW/Speed Cloth - ZCP, Moonroof, non-iDrive - PCD 12/9/10 Painted reflectors, matte black grills/gills, Deansbimmer Belly Pan, DEI Alarm, Homelink/compass retrofit, Passport MAX2 Hardwire, GP Thunder 8500K, modmy3 LED interior, Dinan Mufflers, HRE P40 19" Satin Charcoal, Michelin PS4S |
11-23-2014, 10:47 PM | #14 |
Rep 11,891
11-24-2014, 12:56 AM | #17 |
Rep 1,159
Unless this guy is Jesus, or some type of god who can diagnose problems just by listening, I wouldn't trust him.
Just my $0.02
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
11-24-2014, 02:32 AM | #18 |
Rep 43
Thanks for all the replies! I'm going to stay away from that mechanic from now on for sure. Just out of curiosity someone mentioned rod bearing failure.. What symptoms would this show other than the ticking noise?
11-24-2014, 02:39 AM | #19 |
Rep 955
my understanding is that usually by the time you have any sorts of 'symptoms' its too late.
any sort of knocking / "the wrong type" of clicking / ticking coming from the underside means that the bearings are already fucked and at very minimum, gouging the shit out of your crank. i could be wrong tho... im no expert, just going on what i read in the countless threads here. |
11-24-2014, 02:55 AM | #20 | |
Rep 43
11-24-2014, 11:54 AM | #21 | |
Rep 24,867
Not in space... but in our S65 engine block
11-24-2014, 03:12 PM | #22 |
Rep 295
The mechanic sounds like he is clueless. If this was a normal issue for a M3 you would hear about it. Who changes their manifold every 10-20k miles? This person sounds like a terrible mechanic. Stay away. If you want to help diagnose the ticking sound you can always send in an oil sample to blackstone.
http://www.blackstone-labs.com/free-test-kits.php If there are high levels of copper, lead or iron there may be rod bearing issue. |
Tags |
clicking, cracked, leaking, manifold |
