12-01-2014, 01:29 AM | #1 |
Rep 1,766
My comfort access doesn't lock..
It unlocks just fine when I touch the handle, but it doesn't unlock for some reason. I hear it activate with the little clicks, especially at the gas cap, but it won't lock unless I hit the key fob lock.
Anyone experienced CA acting up like this?
2024 X3 m40i
12-01-2014, 02:05 AM | #2 | |
Rep 3,990
This should solve your issue if what I have said does not help: http://www.bimmerfest.com/forums/sho...d.php?t=613314
2014 X5 50i X-Line // Mineral White
12-01-2014, 08:59 AM | #3 |
Rep 1,417
One reported IPhone interference when fob in same pocket. Probably not your situation as you can unlock but cannot lock.
http://x3.xbimmers.com/forums/showth...uto+start+stop |
12-01-2014, 09:41 AM | #4 |
Rep 1,886
My '14 did this. I could hear something clicking around the gas tank lid but it would take several attempts to get it to unlock. It shows up int the survey too. I never resolved it. The '15 works nearly as effortlessly as the Merc.
12-01-2014, 10:21 AM | #5 | |||
Rep 1,766
Yes, I can hear the function work fine, it's clicking like MattBianco said. Quote:
Yes, same problem, just clicking and not locking, as if one door is still open or as if key is still inside. The funny thing is, I got to office this morning and it first clicked without locking then it suddenly locked. Maybe my phone was in a pocket further away from FOB? I can't tell what it was but my guess is that vehicle thinks key is still inside. I am going to try holding it a bit further out, maybe my "outside" pocket standing away from the car to see what happens. We know at least the function works but something is stopping it from locking.
2024 X3 m40i
12-01-2014, 10:35 AM | #6 |
Rep 1,886
Additional detail: two iPhones got in and out of the '14, and continue to do so on the '15.
At times it would not unlock at all. I'd use the key fob, and afterwards it would work for a while. It was very sporadic and unpredictable. I thought it was just a poor implementation of keyless go. When the '15 arrived, I noticed it works quite well and have not encountered your issue. |
12-01-2014, 11:13 AM | #7 |
Rep 450
I have recently had a problem where the comfort access doesn't unlock when you grab the handle. I put it down to the CA going to sleep if it was left for a while, it hadn't been driven for a couple of days.
Does anyone know if it does go to sleep or do I have a problem with CA not unlocking. I even tried it with the keyfob in the same hand that I was grabbing the handle with, no joy. Unlock with the fob button, no problem. |
12-01-2014, 01:19 PM | #8 |
Rep 753
Drives: 2020 X5 M50i
Interestingly mine will sometimes hesitate to lock until the soft close doors completely close. I had one occasion where I touched the sensor on the door and it did not lock. Like you I used the key fob and it locked right away. It has worked since then very smoothly.
2020 X5 M50i
2015 Porsche Macan Turbo 2017 BMW i3 Tera World |
12-01-2014, 06:05 PM | #9 |
Rep 1,766
It's really odd, I am sure it's just a coincidence, but when I hold and twist my hand it would just lock then, unlocking has no such issue.
2024 X3 m40i
12-02-2014, 09:05 AM | #10 |
Rep 132
This is one of my least favorite features. I had a Audi and my Wifes MB all unlock when you get close, this thing makes you pull on the stupid door handle and usually I have to pull twice before it unlocks on mine.
Not liking this setup. |
12-02-2014, 07:58 PM | #11 | |
Rep 1,766
Ok guys, here is an update, after many tries I realized CA works differently in F15 compared to E70. F15 has different sensors for Lock and Unluck, separately. So to unlock the door, you just grab the handle, to lock you just touch the outside or top & bottom. I have been trying to unlock it by just lightly touching the handle, so it assumes I am trying to get in, it thinks I am actually holding the handle, so now when I use my thumb and index finger to hold the outside portion where keyhole cover is, it locks just fine.
2024 X3 m40i
12-02-2014, 08:23 PM | #12 | |
Rep 38
