12-04-2014, 11:02 AM | #1 |
Joint Chiefs of Staff
4923
Rep 115,999
New - N54Tuning - Tial Q BOV - Now Available!!! - ON SALE!!
Q is the first revision of the original TiAL BOV. The Q bolts up to any standard TiAL flange, no re-welding. This is the highest flowing BOV on the market.
For use on turbo-charged and super-charged applications (Paxton, Vortec, etc.). The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve. The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp uses Stainless Steel hardware for a long lasting, corrosion-free appearance. The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance. The Blow Off Valve also comes with our own machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life. An aluminum or mild steel weld base mounting flange is furnished with each unit. Stainless Steel is available at an additional cost. The use of 6061 aluminum allows the housing to be anodized with a selection of colors. Through countless hours of R&D we were able to make the same size valve flow a staggering 60% more than the original design - that means 60% more air is blown off per cycle! This is the highest flowing BOV on the market. Color anodized aluminum options ( Red, Blue, Black). A single Q BOV can support up to 1,800hp -2psi spring for supercharged applications ORDER LINK http://www.n54tuning.com/index.php?_...&productId=183 |
12-05-2014, 10:33 AM | #2 |
4923
Rep 115,999
09-18-2015, 09:31 AM | #3 |
4923
Rep 115,999
09-27-2015, 03:32 PM | #4 |
4923
Rep 115,999
09-30-2015, 09:09 PM | #5 |
4923
Rep 115,999
10-02-2015, 08:39 PM | #6 |
4923
Rep 115,999
02-06-2016, 02:54 PM | #7 |
4923
Rep 115,999
02-15-2016, 07:53 AM | #9 |
4923
Rep 115,999
Bump for a Great Deal @ www.n54tuning.com
IN STOCK!!! and as always the LOWEST price Guaranteed!! Mike |
02-21-2016, 05:17 PM | #10 |
4923
Rep 115,999
02-26-2016, 01:36 PM | #11 |
4923
Rep 115,999
03-08-2016, 06:10 PM | #12 |
4923
Rep 115,999
10-27-2016, 06:25 AM | #13 |
4923
Rep 115,999
11-01-2016, 06:31 AM | #14 |
4923
Rep 115,999
11-07-2016, 06:26 AM | #15 |
4923
Rep 115,999
12-04-2016, 03:49 PM | #16 |
4923
Rep 115,999
12-10-2016, 08:44 PM | #17 |
4923
Rep 115,999
12-17-2016, 07:32 AM | #18 |
4923
Rep 115,999
12-22-2016, 12:57 PM | #19 |
4923
Rep 115,999
12-28-2016, 07:58 AM | #20 |
4923
Rep 115,999
01-04-2017, 04:48 PM | #21 |
4923
Rep 115,999
01-10-2017, 06:16 AM | #22 |
4923
Rep 115,999
