01-15-2015, 10:21 AM | #1 |
BMW Super Enthusiast
126
Rep 245
e9x floating vs f8x fixed caliper impressions?
I know its subjective but i'm looking for anyone who's used both braking systems to their limits. While you can chime in if you've got the CCB i'm more concerned with your subjective opinions when its come to stopping power and fading. After reading the tech sheet for the F80 it says the brakes are fixed caliper and 4 piston front 2 piston rears vs the floating single piston options.
Thoughts?
'15 ///M3 - Daily ****** '97 ///M3 - Track Car
'04 330ci ZHP - sold **** '08 ///M3 - sold '00 328i - sold ********* '00 323i - totalled '94 325ix - Parted *** '92 318i vert - sold '94 325i - Rear End Total ***** '01 330ci - traded |
01-15-2015, 02:31 PM | #2 |
Go ///M or go home
276
Rep 1,280
I cant answer with personal experience since I've only driven E92 and not F8x, but here is some useful information you might find helpful:
http://www.whyhighend.com/floating-v...-calipers.html http://www.neo-motorsport.com/articles/4 Seems that floating calipers are cheaper, lighter, and last longer (because had one set of pistons on the front vs a fixed has two sets of pistons on both sides of the disc), but could have sticking problems if the caliper does not slide back to its original position. Fixed has more even stopping power but it is heavier and can be costly to maintain/replace. Hope this helps.
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT |
01-16-2015, 03:06 AM | #3 |
Rep 320
Completely stock, ie stock fluid, pads, discs and tyres the F80/82 brakes are better than E90/92.
By better, I mean better feeling and modulation, better release, and more fade resistant. In fact on the track I am yet to feel significant fade on the stock F82 setup during hard 20 track sessions. The pad wear completely stock also seems better, presumably as they are not getting overheated as much. However, I have my suspicions that the stock brake pad compound on the F82 is more track orientated than the stock compound on the E92, which might help with some of the above factors. My tracktime in both cars is pretty limited, 2x track days in each. |
01-16-2015, 01:03 PM | #4 | |
Rep 20,741
Drives: 2021 911 turbo
However, even on the F8X, the stock pads are inadequate for serious track use. |
01-19-2015, 06:57 AM | #5 |
Rep 570
After probably 70 track days on my 2011 E90 M3, there is no question the factory brake design on that car (floating calipers F/R, and the compound (pin floating) rotor) is both functional and highly reliable. With Pagid RS racing pads used every event, and switching back to stock pad for the street, never any rotor deposit/pedal pulsing and the rotors still were in spec (although coming up for replacement)!
The new fixed set-up on the M4, from a design perspective, is superior and more servicable (pad swap via the pad carrier vs. removing the caliper). I'll be tracking my car beginning in April, so we'll see. I expect nothing less than spectacular, given a lighter car, larger rotors, more advanced multi-piston calipers, and ease of servicing. On the road, brakes are overkill, as they were w/the E90, so definitely difficult to compare (Awesome vs. More Awesome?). I never use street pads on-track and vice versa. |
01-19-2015, 07:17 AM | #6 | ||
Rep 20,741
