01-16-2015, 10:26 PM | #1 |
Rep 226
Drives: E93, E38, E53
Comp package springs
Found a local guy selling stock e92 comp. package springs for 150. How much would they lower a e93?
And does 150 sound fair? |
01-17-2015, 11:12 PM | #2 |
Rep 221
Keep in mind I'm pretty new to theses cars but im pretty sure you can't just swap out to comp Springs. I believe the comp package has different spring mounts.
01-18-2015, 04:58 AM | #3 | |
Rep 341
Drives: 2011 E90 M3 W/ ZCP, ZPP, ZCW
E90 M3 W/ ESS VT2-625, Macht Schnell race X-Pipe, UUC Cat-back exhaust, Stoptech ST60
01-19-2015, 04:28 PM | #4 |
Scythe-Meister
90
Rep 1,053
You cannot just slap another M3's springs onto your car, unless you are just after looks. There are a range of springs for different m3 weights i.e. a fully loaded M3 ZCP coupe, will have different springs to a zero optioned M3 ZCP coupe. That being said, ZCP height difference is mainly due to mounts and perches, not springs.
01-24-2015, 03:54 PM | #6 |
Rep 2,940
make sure there are no differences in the stock spring rates for an e93 with the extra 400lbs it carries around. I don't know, but you should make certain before switching to things not designed for the e93.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
04-07-2015, 03:36 PM | #7 | |
Rep 5,482
And the upper mount part number is the same for all.
04-12-2015, 08:29 AM | #9 | |
Rep 7,129
Cheers Edit: here you go, good reading: http://forums.m3cutters.co.uk/showthread.php?t=120370 Last edited by Helmsman; 04-12-2015 at 08:39 AM.. |
04-13-2015, 05:22 AM | #10 |
Rep 1,184
