01-20-2015, 08:10 PM | #1 |
Rep 43
08 M3 Issues
So I got a used m3 7 months ago (08 12/07)
In that span I have had to change an engine coil Throttle actuator Clutch/Fly wheel It barely has 56k miles on it. I thought this was a reliable car. ... |
01-20-2015, 08:27 PM | #2 |
Bad Lieutenant
233
Rep 3,517
There is no such thing as a high performance reliable car ... BUT, clutch/flywheel at that mileage shows it was either abused or just defective.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
01-20-2015, 08:30 PM | #3 |
Rep 43
you're right and I did learn to drive stick on it so I guess I did attribute to some wear but to wear out already after I had it for 6-7 months. I have the model with the discontinued clutch/fly wheel so I have to replace both.
01-20-2015, 09:28 PM | #4 |
Rep 50
01-20-2015, 10:23 PM | #5 |
Rep 730
It will cost you about $3500 because the new flywheel that's very expensive one of part.
08 E90 SSII M3 6MT for track
2015 Lexus RX350 Fsport for wife 2012 Honda Oddessey Touring for kids 2014 toyota Fj cruiser 4x4 for me |
01-20-2015, 10:26 PM | #6 |
Rep 43
01-20-2015, 10:29 PM | #7 | |
Rep 50
Anyone know if you can find an oem clutch/flywheel for lower than that? |
01-20-2015, 10:35 PM | #8 |
Rep 11,891
heaven forbid you had to change the oil in the car
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
01-20-2015, 10:43 PM | #9 |
Rep 43
Look up Luk they carry the OEM clutch/flywheel for a lot cheaper an indy shop quoted me 700.
01-20-2015, 10:50 PM | #12 | |
Rep 3,387
01-20-2015, 11:01 PM | #14 |
Rep 50
Couldn't find anything on the luk kits he was referring to on their website. Every other source I looked at had e46 and earlier luk kits.
I did find this through get bmw parts: https://www.getbmwparts.com/parts/20...section=CLUTCH I know they changed the flywheel for post 08 M3s so that should be it. Everything else I found was aftermarket. Maybe dig around ebay also. |
01-21-2015, 08:59 AM | #15 | |
Rep 746
01-21-2015, 09:31 AM | #16 |
Rep 3,994
A coil and actuator ain't that bad. Clutch was driver error.
All things considered that doesn't seem unreliable at all. Was your previous car a honda or toyota?
01-21-2015, 09:32 AM | #17 |
Rep 3,482
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
01-21-2015, 10:16 AM | #19 |
Rep 1,197
Drives: 2021 F87 M2c. LBB, 6mt
Thanks for the pic of the gauges. You should really wear your seat-belt and check your tire pressure!
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
01-21-2015, 10:28 AM | #20 | |
Rep 1,773
Drives: 328it, RIP M3, E46 Sold
2. I'm at Idle. 3. Stop complaining about your ///M and suck it up; or sell it.
01-21-2015, 11:21 AM | #21 |
Rep 928
I think every single M3 gets a lot of repairs and require excessive maintenance regularly.
Since I bought my car they replaced the drive shaft, o2 sensor and, temp sensor a total of 4k in repairs. I also had to take it in for the 60k service which is like oil/air filter and stuff. |
01-21-2015, 11:22 AM | #22 |
Rep 3,994
You can code this out if you don't plan to switch back. I did this on my US spec M3, coded it to have the CAD tire monitoring setup which doesn't use the in wheel sensors.
