BMW M3 Forum (E90 E92)
Mporium BMW
      01-20-2008, 10:50 AM   #1
Bastet
Bastet's Avatar
Belgium
18
Drives: M3 E92 aka 'Batmobile'
Help please - Brake discs - is this normal ?
Could someone tell me if it's normal that one of the break discs is grooved (1st photo) ? All the others are really smooth (like in the second photo) but one has grooves. Should I be worried/take the car back to the dealer/just forget about it and enjoy driving ???
      01-20-2008, 11:06 AM   #2
GregW / Oregon
Commander-In-Chief
2122
Scored brake rotor
No, it's not normal, but not unusual. Probably got some debris caught between the rotor and disc. It shouldn't have much effect on braking, but I''d show it to the dealer. They may well go away on their own in a few thousand miles.
On GM cars rotor grooves of up to .060 inch are acceptable if the rotor meets all other specifications. Not sure what BMW specs say.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      01-20-2008, 11:07 AM   #3
Epacy
Reincarnated
Epacy's Avatar
245
Drives: 02 Maxima SE
2008 M3  [0.00]
I do see the grooves in the first pic. I would say if no other brake discs have this scoring, you might want to take it in.
      01-20-2008, 11:10 AM   #4
Bastet
Bastet's Avatar
Belgium
18
Thanks guys ! I knew it - I hate returning to the dealers for something like this !
      01-20-2008, 11:23 AM   #5
Gearhead999s
Gearhead999s's Avatar
817
Drives: RR Velar R=Dynamic M2C R1200GS
Those brakes are not even broken in yet as the machining marks are still on the surface.Read this link about brake & rotor "bed in".I have been using the methods used here with very few braking problems in both street & race cars.
http://www.stoptech.com/tech_info/wp...contents.shtml
      01-20-2008, 11:26 AM   #6
Bastet
Bastet's Avatar
Belgium
18
thanks !
      01-20-2008, 04:55 PM   #7
heyimsexy
Drives: e36
not normal. i would only be concerned if youre having vibrations or squeaking. if its not bothering you in any way, dont take it in, because you can be sure the dealer is gonna pile on the bullshit and youre gonna be spending $$$.
      01-20-2008, 05:02 PM   #8
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
I would not follow this advice.
      01-20-2008, 05:04 PM   #9
lucid
lucid's Avatar
Drives: E30 M3; Expedition
i don't think there is much downside here. it can make noise. it's not as if the groove is so deep that the rotor will crack. the dealer will want and love to replace the pads and the rotor, and that will cost dearly. if it starts vibrating, that would be problematic because that can affect performance, at which point i'd take it in, so i agree with the sexy member. or i guess the alternative would be to take it in and ask them to remove whatever is stuck on the pad, but they most likely won't want to do that saying they need to replace everything. if there is nothing stuck on the pad, one could argue the pad was defective.
      01-20-2008, 06:37 PM   #10
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
If there is something stuck between the pad and rotor, you would most likely hear it at all times. That space is fairly small. Also, it looks like you have three marks. Would be hard for three different pieces of debris to be there. Looks most likely your pad is the culprit.
If you don't hear it at all times, it seems like a problem with the pad scoring the rotor. Which the dealer would have to replace.
      01-20-2008, 07:14 PM   #11
Stahlgrau
Drives: Backwards
Wouldn't replacement be covered under warranty?
      01-20-2008, 07:17 PM   #12
lucid
lucid's Avatar
If they attribute it something getting caught in the pad, they would probably argue that is not warranty related. If they attribute it to the pad itself, then they would have to cover it given it's a brand new car. In the US, it wouldn't be an issue as we have the 4 year warranty+free service deal, so it wouldn't matter what has caused it.
      01-20-2008, 09:39 PM   #13
GregW / Oregon
Commander-In-Chief
2122
That would most likely be covered under free maintenance in the US, but they don't get this in Europe, despite paying more.
      01-20-2008, 10:37 PM   #14
OzStriker
OzStriker's Avatar
Australia
61
Drives: Ford Falcon Ute, Ducati 1198S
+1 on those brakes not being broken in.
You can still see the diamond criss cross marks from original manufacturing.
Go bed them in on a freeway early morning and see what happens.
      01-20-2008, 10:45 PM   #15
GregW / Oregon
Commander-In-Chief
2122
Break in of brakes
Good advice.
      01-21-2008, 04:37 AM   #16
Bastet
Bastet's Avatar
Belgium
18
Our warranty covers pretty much everything during the first year, so I'll probably go show the discs to the dealership anyway, just to be on the safe side...
      01-21-2008, 08:26 AM   #17
GregW / Oregon
Commander-In-Chief
2122
Rotor scoring
I doubt this is technically a warranty issue (defective parts), but likely will be considered a wear issue. Good luck with the dealer. If they don't think it's important, just drive it and the rotor may even out.
      01-21-2008, 09:00 AM   #18
Gearhead999s
817
I would not worry about it,because one of the problems with drilled discs is that the scoring of the disc face is pretty normal.I am not a fan of drilled discs as when used on track they tend to have cracks that start ot the holes,whether they are cast or machined after.On Porsches they are cast and they also do crack after a few hard days.A lot of the scoring on your discs might have been caused by rust particles coming out the holes and getting collected on the pads.On a lot of street Porsches I have noticed brake pad material actually filling up these holes.I prefer Slotted discs,much more servicable for hard use.
      01-21-2008, 09:41 AM   #19
gblansten
gblansten's Avatar
1977
Drives: 23 Tesla S Plaid
I don't think that those disks are broken. Long-term if you have breaks instead of brakes you'll be in the shop a lot.
Dew yew sea what eye did their?
      01-21-2008, 10:37 AM   #20
southlight
Moderator / European Editor
southlight's Avatar
1545
Drives: X3M
Nice attitude, n00b.
Best regards, south
      01-21-2008, 11:54 AM   #21
gblansten
gblansten's Avatar
1977
Best regards, south
Laugh a little there chief. Relax.
Minus whale because for all intensive porpoises life is two short.
Ultimate regards,
GBlansten
      01-29-2008, 01:50 PM   #22
Bastet
Bastet's Avatar
Belgium
18
Just thought I'd let all those who read this know that after a few days of working the brakes pretty hard the grooves are virtually gone. I'm quite surprised that they have reduced so much as i could easily feel them on the surface.
Makes me wonder how the discs and pads will wear the miles??? Only time will tell, but hopefully they'll last a good while.
m3post
